Question about Easy Spirit ESTRAVELTIME Shoes for Women
Can I wash beige easy spirit estraveltime where soiled around inside of heel?
Sludge On white clothes
WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Aug 09, 2013 | Fisher and Paykel Washing Machines
Tip
Hidden Gunk in Your Dishwasher
<span><span>You may be surprised to know you probably have "gunk" around the door seal and on the inside bottom of the door of your dishwasher. Using an old toothbrush or a soft cloth and some <a href="/#">white vinegar</a> or a mild cleaning product, rub around the door gasket and the edge of the door. You'll probably be amazed at the residue that you remove. You may have to wipe and wash several times to get off all the accumulation.<br />The reason this debris accumulates is that the water and <a href="/#">soil</a> seep under the seal but are not rinsed away. Because we can't see the <a href="/#">soil</a>, it hardens and the next time the machine is run, more soil is deposited. Eventually, the soil begins to spoil and an unpleasant odor develops. </span></span><br /> <span><span>Another trick is to GENTLY rub just under the gasket with a wooden toothpick. This will remove debris lodged under the gasket.</span></span><br /> <span><span>Cleaning the bottom and edges of the door will help to prevent unpleasant odors coming from your dishwasher.</span></span>
on Dec 02, 2010 | Dishwashers
My Fisher and Paykel Aquasmart is leaving white marks on my clothes. I am using the correct washing liquid, so how can I fix this? I am sick of re-washing half of my clothes
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
May 24, 2013 | Fisher and Paykel Aquasmart wl80t65c
How do I remove crud from inside a washing machine?
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Dec 19, 2012 | Fisher and Paykel Washing Machines
Fisher Paykell washer left black grease spots on some clothes
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
9.2 Soiling
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3 Linting
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
9.5 Black Marks on Clothes
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
9.6 Grey Marks on Clothes
this is a problem it is recommended that the machine be periodically filled with hot water, plus
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
9.8 Tangling
other. Do not load the machine by wrapping clothes around the agitator.
Sep 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel washing machine GW703-U leave black spot on clothes during final spin
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Jan 30, 2012 | Fisher and Paykel Washing Machines
We just moved into a house with a Bosch SHY66C05UC dishwasher and it emits the foulest smell whenever we open the door. We only do the dishes every 3 days. Can anyone suggest a solution? By the way, the...
You probably have "gunk" around the door seal and on the inside bottom of the door. Using an old toothbrush or a soft cloth and some white vinegar, rub around the door gasket and the edge of the door. You'll probably be amazed at the residue that you remove. You may have to wipe and wash several times to get all the accumulation off.
The reason this debris accumulates is that the water and soil seep under the seal but are not rinsed away. Because we can't see the soil, it hardens and the next time the machine is run, more of the soil is deposited. Eventually, the soil begins to spoil and an unpleasant odor develops. Try the door cleaning first and then run a cycle when the dishwasher is empty, using about 1/4 cup of white vinegar. This should be all you need to do.
I hope this helps with your "stinky" problem. If it does, please let Fixya know by rating my solution!
Good luck
Dec 05, 2010 | Bosch 24 in. SHY66C05 Stainless Steel...
Odor
Good luck
Dec 01, 2010 | Dishwashers
Our dishwasher stinks
Good luck.
Nov 27, 2010 | LG Dishwashers
Dishes and glasses are not coming out clean even inside of dishwasher has some residue left on it after washing
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
Post your model number and I'll try to find a diagram which shows you your parts.
Apr 19, 2010 | Kenmore 15121 Built-in Dishwasher
Easy Spirit ESTRAVELTIME Shoes for Women Logo
23 people viewed this question
Top Easy Spirit Clothing Accessories Experts
Da Doc
Tom Chichester
Are you an Easy Spirit Clothing Accessory Expert? Answer questions, earn points and help others
