Question about DaVinci Emily Crib
Barrel nut replacement
I lost 2 barrel nuts when moving. Where can I get replacements?
2 Suggested Answers
  • 317 Answers
SOURCE: i have lost some of
Yes sir just go to a hardware and bring a sample of the parts you want to buy replacements and ask the sales attendant of the hardware if they have those kinds of barrel nuts..
Posted on Jul 13, 2011
I purchased bunk bed for my kids in US, Creekside taffy twin/full step bunk bed.
The number of different sizes is confusing and it is important to measure carefully in order to order the right ones.
Few people will be able to tell you what size you need and I can't. When I bought two sets of bedbolts online a while ago I found the barrel nuts and bolts were supplied in sets and I needed to know the bolt diameter and length and the diameter and length of the barrel nut. The website I used showed how to measure and if you still have a nut this will be simple for you.
I had no nuts or bolts and had to start from scratch, which was simple once I had found something like a rod or tube that was a good fit in the bedframe - a matter of inserting it and marking it and then measuring the diameter and the distance to the mark.
In reality I found the sets of bolts so cheap it made little sense not to order spares. They arrived 2 days later. If you are in any doubt why not order a few sizes...
The method of fixing the bedframe together is so crude even the wrong size of nut and bolt will sometimes be enough to hold it together, though for strength and reliability the right size is obviously better.
I suggest a google search for bed bolts and nuts and then visit a few sites to check ways of discovering how to measure.
Apr 17, 2017 | Baby Gear
I am missing all of the screws for the crib. We recently moved and lost all the screws for the crib.
Lowes carries most bolts and barrel nuts. Local small hardware stores may have longer bolts if needed. I sometimes use a bolt specialty business for unique bolts. Most cribs use either a metric set or SAE. If you are replacing the complete set choose whichever is easiest to find. If they bed has glued in threaded nuts go with the matching bolts style, metric or SAE.
Jan 15, 2013 | Delta Eclipse Dark Cherry Finish 4-in-1...
Weller Solder Station EC2000 display light but iron doesn't heat
Hello theree and welcome to fixya
you'll find the datasheet for your model here, including troubleshooting guide, assembly diagram and parts list: http://www.action-electronics.com/pdf/wtcpltechsheet.pdf
In my case the magnetic switch was still working (there's instructions on how to test each part) but the heater barrel was open. I replaced the barrel and the nut (the newer barrels are slightly larger in diameter, so you might as well get a barrel nut at the same time) and the iron works perfectly.
You can get these parts from Digikey:
EC234-ND - HEATER ASSY FOR A TC201T IRON
BA60-ND - ASSY BARREL NUT FOR PES51&50
SW60-ND - SWITCH ASSM FOR SOLD PENCIL (magnetic heater switch)
Some are listed as 0 quantity, but they order them and I got mine in about 2 weeks. Other replacement parts are available, but if you have to replace too much (or the more expensive parts) on the iron you might as well buy a new iron. When mine broke, I fixed it and purchased a new weller that was adjustable for $100. Now my old one is the backup, and I don't mind bringing it to electronics group meetings.
However, this is a worthwhile iron to fix if the cost is not too great. The new fancier models have more features, but you really can't beat how durable and usable these old wellers are. While you're at it, you might as well get another tip or two.
Oct 24, 2011 | Welding Tools
I have lost some of the barrel nuts that i need to put the crib together, can i purchase replacement parts
Jul 13, 2011 | DaVinci Emily Crib
When shifting my 2005 flhtp seem like it clunks when going into gear upshift and downshift is that normal or do i need clutch adjustment
I'd adjust the clutch. With the engine off, put the transmission in first gear. Pull the clutch in and hold it. Try to start the engine. If the bike pulls forward, you need to adjust the clutch.
Find the rubber boot that covers the cable adjuster on the clutch cable and move it up or down. Loosen the lock nut and turn the adjuster inwards getting as much slack in the cable as possible.
Then, take the derby cover off the primary. You'll see an adjuster screw in the middle of the clutch assembly. Loosen the lock nut and turn the adjuster inwards until you feel a resistance. DO NOT FORCE THE SCREW OR YOU'LL DAMAGE YOUR INNER CLUTCH HUB. Turn the screw in until you feel a resistance. Then, back it back out 1/2 turn and tighten the lock nut. Replace the derby cover.
Go back to the cable adjuster and turn the adjuster barrel out until you have about 1/8 inch of freeplay in the cable. Tighten the lock nut and replace the rubber boot.
Good Luck
Steve
Jun 04, 2011 | 2005 Harley Davidson FLHTC - FLHTCI...
Trying to put together Freeport convertible crib. In figure one where should the barrel nut be placed at the top of back rail? Should there be a pre-drilled hole to place the barrel nut into, like the...
Yes and it should be under the top edge of the rail so it isnt visible when the
crib is assembeled. There should be a predrilled hole for the barrel nut to fit up into.
Mar 26, 2011 | Graco Lajobi Kendal Convertible Crib
It will not heat up, maybe tip needs to be cleaned, if so how? I lost the manual. Thank you..
I am assuming that you installed a new tip. Note, the tip ends have to be 3/8 of an inch 90 degree bend so that when you insert the tip leads into the barrels, they go into the small holes in the barrels. Also note, the nuts to tighten the tip into the gun have to be installed onto the tip leads before bending the leads. Now when the tip is installed this way, the nuts tighten and hold the tip in the barrel. This tightening of the nuts allow the tip to have a good electrical connection to the barrels and this is what allows the tip to heat. You actually have an electrical current that passes through the barrels and the tip. It is a very low voltage (around 2) but a very high current. Over time the tip will not heat, this is a sign to either tighten the nuts, or look at the tip to see if it has a break in it. If it has an open, then it is time to change the tip.
Feb 12, 2011 | Weller 8200 Soldering Gun
Can't remove an inline fuel filter nut
If I were you, what I would do is cut the line, try to get it out of the 1" nut that is in the carb in a vise. Then replace the line from the fuel pump up, if I remember it's 5/16" and maybe 3-4 ft long. Being a L6 motor fuel pump is easy to get too. If you can't get line out of 1" nut they do sell the at auto parts stores in the help racks.
May 03, 2009 | Chevrolet Classic Cars & Trucks
Barrel nuts busted for toddler bed side-rail.
JUST BOUGHT 1 PACK OF 4 BARREL NUTS FOR STORKCRAFT CRIB AT CANADIAN TIRE FOR $3.59. WORKS GREAT!
Jan 09, 2009 | Storkcraft Baby Rochester Crib
Car stoped moving
there is the chance of yes and there is that chance of no
the axle if seized in the pumpkin i call it yes the car wont move
axles are balanced so that the car runs smooth if car stopped moving then the axle siezed up
if the nut came off you put a new nut on with one of those fast clips i forgot what there called but there is a little hole drilled on axle to keep nut from moving and it looks like a bobby pin can slide in there but thats not what the certain pin is called
you can move the car a little bit without nut in slow idle 2 miles per hour you dont want to stress axle any further than whats been stressed
not stable to drive until replacement nut is put in its place
May 15, 2008 | 2004 Saturn VUE
DaVinci Emily Crib Logo
Top DaVinci Baby Gear Experts
Dennis Fitzsimmons
Level 1 Expert
Are you a DaVinci Baby Gear Expert? Answer questions, earn points and help others
