Question about Seiko Men's Stainless Steel Chronograph
Main second hand on Seiko sna 30 does not work
5 Suggested Answers
  • 110 Answers
SOURCE: SEIKO 7D48.... WATCHING SHOWING CORRECT
Second hand could be stuck against the crystal inside or it is slipping on the shaft. Both of these conditions can be fixed but the case back would have to be removed and the movement removed to fix this problem
Posted on Nov 06, 2009
  • 3 Answers
SOURCE: seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Posted on Jan 03, 2010
SOURCE: Seiko Chronograph 7T32 minute hand inactive after battery replace
you often need to do a full reset on 7T32s (& other seikos) after a battery change. there is a small reset contact in the rear of the movement which needs to be shorted to the top of the battery (the movement is engraved with wording to this effect, something like "AC reset", I can't remember exactly). you might also try pulling out the crown all the way (2 clicks) then holding both upper pushers in for a few seconds. it's unlikely to be a buggered motor unless it's one of the subdials that's failed.
hth-
duncan.
Posted on Mar 11, 2010
  • 122 Answers
SOURCE: I have a Seiko Titanium Chronograph certified
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Posted on Jun 06, 2010
Hello. I have a Seiko 7t62 ojpo chronograph. The small second hand will run for about 20 minutes then stops. As a result, the main minute and hour hands stop working. Everything else works. Any ideas?
You have a fairly premium watch and some versions are more premium than others. Your watch clearly needs attention and that should be entrusted to a Seiko dealer or to the manufacturer. Once the case has been opened the sealing must be retested to ensure it meets specification. If this isn't done as part of the repair or service or battery fitting there is little point in having a watch with such a high specification.
Jan 04, 2017 | Seiko Watches
Hi, got a seiko 7T92, the stopwatch second hand, can this be made to work as a second hand or is it only for the stopwatch function, it's annoying that it's still all the time!
If you can have both clocks running at same time, yes but they'll be on different screens. you just have to go back and forth between screens.
Apr 02, 2016 | Seiko Watches
The chronograph second hand now resets to the 5 O-Clock position?
I have found instructions that tell you how to reset the hands but there are several buttons on your watch and to avoid confusion you really need to see a diagram.
You can do this by going to the Seiko web site (seiko.com), click on "support", then "instruction booklets".
Scroll down the next page and you will see a list of the watches made by Seiko. Select yours and download.
Go to page 16.
Jan 23, 2010 | Watches
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
How to set my seiko sna663 divers watch
Hello
Ok, i found a link where you cand download the manual for your seiko SNA series.
Just click on the link below and you will be directed to the page where you can download the manual.
http://safemanuals.com/user-guide-instructions-owner-manual/SEIKO/SNA%20SERIES-_E
Kind regards
Andrea
Dec 06, 2009 | Bulova Watch
Seiko watch stop watch needs resetting
Tom
Nov 10, 2009 | Seiko Men's Stainless Steel Chronograph
SEIKO 7D48.... WATCHING SHOWING CORRECT TIME(WORKING PROPERLY).. BUT SECOND HAND NOT MOVING.
Nov 05, 2009 | Seiko Kinetic watch
hth-
duncan.
Feb 20, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Seiko SNA413P1 second hand not on 0 exactly
It is probably the way the second hand was placed onto the watch when the watch was put together. The hand will only move in a set interval so if it's "off" you cannot fix it unless you have someone take the watch apart. I would not worry about it being a fake because honestly Sekio watches are not expensive enough to fake. Here's a good rule of thumb, if the watch cost under $1000 then it is probably not going to be something that people will make a counterfeit model of. Finding a "fake" Seiko, Citize, Bulova, or any mid-level watch is not likely.
Jan 02, 2009 | Seiko SNA413 Wrist Watch
Seiko Men's Stainless Steel Chronograph Logo
18 people viewed this question
Top Seiko Watches Experts
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
