Question about Sony NWZ-E438F Digital Media Player
Freezes on the creating library screen
I've had mine for about three months and just ran into the same problem. I'm not sure what triggered mine, though. I haven't downloaded any new songs in weeks. It worked just fine for my three-hour flight home. When I tried to use it at the gym, it just froze on the Creating Library screen. I've tried the reset button a number of times. I've even tried to format it without any success.
  • Sony Master
  • 13,433 Answers
Reformat the player in the settings menu. If this problem persists, contact sony or your dealer for warranty repairs.You can call sony while your getting it on warranty repairs you can ask if they have other suggestions. three months old, should have atleast year warranty.
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=NWZE438F
on above page you can contact sony support, phone, email, live chat. they will most likely go over the reset, format and firmware upgrade with you.
and if noting helps they should tell you what to do about it where to send it or who to contact.
Posted on May 21, 2009
I HAVE A RYOBI PRESSURE WASHER 3100 PSI WITH HONDA ENGINE PURCHASED FROM HOMEDEPOT USED IT 2 WEEKS AGO RAN PERFECT TRYED USING YESTERDAY AND I HAVE NO PRESSURE THE UNIT IS ONLY 10 MONTHS OLD ANY SUGGE
  • I have the exact same pressure washer..bought 10 months ago from Home Depot with the same problem..no pressure. Have you had any luck finding out what the issue is?
Jul 22, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Juno (Janome) Serger thread not interlocking?
if the serger is new I suggest taking it back and tell them what the serger is doing.
there could be a mechanical problem with the serger or it could be out of time.
Jul 25, 2013 | Janome Sewing Machines
Vista Home....Automatic restore points are not being saved....I can manually enter them and they show up on the drop down table....I have both drives checked off to allow automatically creating restore...
Hi g502,
Here are some helpful tips that you may use on how to Change the Automatic System Restore Point Settings in Vista Task Scheduler.
By default System Restore is scheduled to create a restore point at 12 AM every day (Daily trigger) and at every system startup (At startup trigger) in Task Scheduler if any system changes were made from the last time it checked. This will show you how to change these schedule settings, or disable one or both triggers.
Warning:
System Restore will need to be turned on for this scheduled task to be able to run.
1. Open the Start Menu.
A) In the white line (Start Search) area, type taskschd.msc and press Enter.
B) Go to step 3.
OR
2. Open the Control Panel (Classic view).
A) Click on the Administrative Tools Icon.
B) Click on Task Scheduler.
3. Click on Continue in the UAC Prompt.
4. In the left pane click on the triangle next to Task Scheduler Library, Microsoft, and Windows to expand the folder tree. (See screenshot below step 5)
5. Click on the SystemRestore folder.
A) Choose a option or options below to do.
OPTION ONE
To Disable or Enable this Task Completely
6. To Disable this Task Completely -
NOTE: This will disable both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers regardless of how they are set individually. You will not have anymore automatic restore points created with this task disabled. You can still manually create a restore point though. For how, see: How to Create a System Restore Point in Vista
A) In the middle pane, right click on the SR task and click on Disable. (See screenshot below step 5)
B) Go to step 22.
7. To Enable this Task Completely -
NOTE: Check to make sure that each Daily (step 12 in OPTION TWO) and At startup (step 17 in OPTION THREE) trigger is also set as Enabled.
A) In the middle pane, right click on the SR task and click on Enable. (See screenshot below step 5)
B) Continue to OPTION TWO.
OPTION TWO
To Change Only the Daily Trigger Settings
NOTE: You will need to have the task enabled in step 7 to use this trigger. This is the trigger that creates a restore point at 12 AM every day by default. If you do not want to change these settings, then continue to OPTION THREE.
8. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
9. Click on the Triggers tab. (See screenshot below step 10)
10. Click on the Daily trigger to highlight it and click on the Edit button.
NOTE: These are the default settings for the Daily trigger in the screenshot below.
11. To Disable the Daily Trigger -
NOTE: This is if you only wanted to have restore points create with the At startup (OPTION THREE) trigger instead.
A) Uncheck the Enabled box and click on OK. (See screenshot below step 12)
B) Continue to OPTION THREE.
12. To Enable the Daily Trigger -
A) Check the Enabled box. (See screenshot below)
B) If the default settings for the Daily trigger schedule are not what you want, then make any changes that you would like.
NOTE: For more details about each of these settings, see STEP FIVE here: How to Create a Task in Vista Task Scheduler
C) Click on OK.
D) Continue to OPTION THREE.
OPTION THREE
To Change Only the At startup Trigger Settings
NOTE: You will need to have the task enabled in step 7 to use this trigger. This is the trigger that creates a restore point at every system startup by default. If you do not want to change these settings, then continue to OPTION FOUR.
13. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
14. Click on the Triggers tab. (See screenshot below step 15)
15. Click on the At startup trigger to highlight it and click on the Edit button.
NOTE: These are the default settings for the At startup trigger in the screenshot below.
16. To Disable the At startup Trigger -
NOTE: This is if you only wanted to have restore points create with the Daily (OPTION TWO) trigger instead.
A) Uncheck the Enabled box and click on OK. (See screenshot below step 17)
17. To Enable the At startup Trigger -
B) To Speed Up Startup Time - Make sure that under Advanced Settings, the Delay task for box is checked and you have an amount of minutes set that you want for System Restore to run after startup.
C) If the default advanced settings for the At startup trigger schedule are not what you want, then make any changes that you would like.
D) Click on OK.
E) Continue to OPTION FOUR.
OPTION FOUR
To Change the Conditions for the Task
NOTE: You will need to have the task enabled in step 7 first. This will effect how both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers run. If you do not want to change these settings, then continue to OPTION FIVE.
18. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
A) Click on the Conditions tab. (See screenshot below)
NOTE: These are the default settings for the Conditions tab in the screenshot below.
B) Make any changes you would like.
NOTE: For more details about each of these settings, see STEP SEVEN here: How to Create a Task in Vista Task Scheduler
C) Continue to OPTION FIVE.
OPTION FIVE
To Change the Settings for the Task
NOTE: You will need to have the task enabled in step 7 first. This will effect how both the Daily (OPTION TWO) and At startup (OPTION THREE) triggers run. If you do not want to change these settings, then continue to OPTION SIX.
19. In the middle pane, right click on the SR task and click on Properties. (See screenshot below step 5)
A) Click on the Settings tab. (See screenshot below)
NOTE: These are the default settings for the Settings tab in the screenshot below.
NOTE: For more details about each of these settings, see STEP EIGHT here: How to Create a Task in Vista Task Scheduler
C) Continue to OPTION SIX.
OPTION SIX
To See the Task History
NOTE: This will show you what the run and error history for this task is. This can be handy to help troubleshoot any problems with the task, or you just want to see when it ran. If you do not want to see the history, then go to step 21.
20. In the middle pane, right click on the SR task and click Properties. (See screenshot below step 5)
NOTE: You can also just click on the History tab in the bottom half of the middle pane instead.
A) Click on the History tab. (See screenshot below)
NOTE: In the bottom pane you can get more details about a selected history event listed in the top pane.
B) Go to step 21.
21. Click on OK. (See screenshots from below either steps 10, 15, 18B, or 19B)
22. Close Task Scheduler.
Hope it helps
Thank you for using FixYa.
Aug 31, 2011 | Computers & Internet
Wont turn on always freeze on creating library screen
Try a hard reset.If still the problem persists. Ask the telephone tech to install a new firmware.Take care all your saved data and contacts may be lost.
Good Luck
Aug 20, 2009 | Sony Walkman NWZE438FB Digital Media...
Sony NWZ-436F freezes when creating library
Old post I know, but i had a similar problem...
I think it has to do with the file types you upload - had the same issue, and through trial and error I finally noticed one album I uploading was an m4a format. When I would upload several files stepwise, making sure that the player starts after each upload, everything would be fine until I tried the m4a files - it would freeze on the creating library startup screen. This was for the same model as billybraga. Annoying.
Jun 25, 2009 | Sony NWZ-E436F MP3 Player
Thomson DT16300 TV Recorder Continually Freezes
Just got off the phone to TopUp TV and they knew how to sort this out.
Follow these steps
1. Turn on unit and press menu
2. choose set-up
3. then choose Help
4. On the help screen type the number 1397 on your remote - This will take you to an Engineer set-up screen.
5. Scroll down to option 7 (disable library video window) and toggle this option to "YES"
navigate back to your programs and delete the recording that was giving you the problem.
Oct 07, 2008 | Televison & Video
Can see screen for one second
I had mine for almost 3 years and last month ran into the same problem and i take good care of it. I turn it on it stays on for a 1-3 sec and goes black. can't figure out what it is
Apr 19, 2007 | Liquid Video L17LCD2 17" Flat Panel LCD...
Sony NWZ-E438F Digital Media Player Logo
35 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
