Question about Microwave Ovens
Reset microwave some features are not working
How to reset the clock on a Panasonic NN-SA651S microwave.
hi carol.
try this,if this does not work go to the link.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set. You are now ready to use your new Panasonic Microwave Oven. When you first turn on yourmicrowave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . .
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How to reset the clock on Panasonic NN SA651S microwave Google Search
Nov 07, 2017 | Panasonic Microwave Ovens
Microwave says refer to instructions where are they?
Google the brand of your microwave and you may find help via support, particularly if you find the model number on the machine. Sometimes you can locate a user manual if you Google the brand plus the model number and add user manual to the search.
Some brands allow a soft reset by depressing OFF/CLEAR. and keeping it depressed for about 3 seconds. Sometimes, they can be reset by pulling the power cord out of the wall and waiting 60 seconds before replugging it. You then reset the clock on some microwaves. Again, it depends on the brand and features.
Nov 25, 2014 | Microwave Ovens
Lg microwave mv2297fspl
Magnetron is gone, just to be sure remove the microwave and use on a different socket. sometimes the breaker becomes faulty after 10 AMPS.
Tony
Nov 21, 2013 | Microwave Ovens
Maytag microwave cook delay - first minute on timer no heating, then works fine
Not a feature I've heard of.
I would do a hard reset by unplugging the oven for a minute or two, setting the clock, then trying again.
If it still does this, I would contact Maytag customer service at the number in the owner's manual.
Dec 25, 2012 | Maytag MMV6180WS Over the Range Microwaves
Please could you tell me if i have a reset button and where is this located
If your microwave has stopped working it could be the automatic shutdown feature. This occurs when it has overheated. Just unplug it and open the door and wait for about 10 minutes for it to cool off and it should work fine.
Mar 27, 2011 | Microwave Ovens
Microwave was run with nothing in it
Well sorry to break it too you, but the oven has been compromised. DO NOT USE! It doesn't turn on because the safety features have worked properly and have saved your home from severe damage. Lesson learned. /shrug
Jun 12, 2009 | Sharp R-930AK Convection/Microwave Oven
Child sign in window of microwave ,cant start it panasonic
On my NN-L738BA there is a Child Lock feature.
You set the child lock by pressing the Start button 3 times.
If the Child Lock is enabled it displays the word :CHILD".
To disable this feature on my microwave the manual says to
press the Stop/Reset 3 times.
Check your manual for the Child Lock.
Mar 06, 2009 | Panasonic NN-S541 Microwave Oven
Control panel on a whirlpool microwave
SOME ELECTRONIC CONTROLS HAVE A LOCKOUT FEATURE THAT IS ENGAGED AND DISENGEGED BY HOLDING A CERTAIN BUTTON FOR 5 SECONDS. LOOK FOR A LOCK PAD AND HOLD IT FOR 5 SECONDS TILL IT BEEPS.
IF NOT AVAILABLE, THE TOUCH PAD MAY BE UNPLUGGED FROM THE MAIN P.C. BOARD OR MAY BE DEFECTIVE.
ALSO, TRY UNPLUGGING THE MICROWAVE FOR 5 MINUTES
TO RESET THE MICROCOMPUTER, THEN PLUG IT BACK IN AND SEE IF IT WORKS.
AN ELECTRICAL OUTLET NOT WIRED WITH PROPER POLARITY OR NOT GROUNDED CAN AFFECT ELECTRONIC APPLIANCES ALSO.
Mar 26, 2008 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
230 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
