Question about Garmin (010-00583-00) for nuvi 750/760/770
Fuse on gps charger - Garmin (010-00583-00) for nuvi 750/760/770
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Fuse is in the tip of the charger.
Posted on Aug 07, 2014
Nuvi 255w-Where can I get a replacement fuse for the car powercharger? What is the fuse number?
On the plug charger unscrew the silver or black bottom tip of plug.. you can probably get a fuse from radio Shack or any Electrical supply store.
Oct 22, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin GTM 25 Charger is not charging GPS, but the red light is coming on when plug in to GPS and Cig lighter. Could this be a fuse in the charger?
Unscew the Cig lighter plug silver or black tip part, the fuse in located in there, be careful its sping loaded....check fuse should be a 3 A fuse any Radio Shack should have it or auto store
Sep 22, 2010 | Garmin GTM 12 FM TMC Traffic Receiver...
The car charger wont charge the gps.
If the USB charger does, then check the fuses in your vehicle - also, there is a fuse at the tip of the car charger. The black plastic unscrews at the tip to reveal the .5A slow blow fuse.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 04, 2010 | Garmin nuvi 260W GPS Receiver
GPS will not operate even when on the charger. Could there be a problem with a fuse
First check the power light on unit when attaching car charger, if there is nothing some chargers have a fuse in the end of the charger, but if there is a green light there could be something wrong with either your battery or your unit
May 07, 2010 | Tomtom ONE 3RD EDITION GPS Receiver
I keep blowing fuses in the car charger for my Garmin Nuvi 660
What happens when you replace the fuse, plug in the charger without plugging the charger into the 660? Does it blow then? If not, the 660 is damaged internally and causing the fuse to blow. If it still blows, then there is a problem in the charger.
http://www.sharc.net/gps_charger_repair.htm
- Jim
Nov 17, 2009 | Garmin Nuvi 660 GPS Receiver
I have a externial GPS system that will not work in the cars accerse, but will work when pluged in to a house out let, not sure if the GPS to car connecting wire is bad ,or something in the car (fuse) is...
while its plugged in to the car outlet, make sure the green (some have red) light is on, on the adapter.if it is not on, try a charger you know is good in the same outlet to verify the outlet is good. if it is, check the end of the charger that plugs in to the car outlet. check the fuse in the tip of the car charger(adapter) by unscrewing the silver tip off the charger and remove the fuse and see if its blown. take the fuse to a local electronics store for a replacement.
Sep 22, 2009 | Magellan RoadMate 1470 GPS Receiver
Car charger for nuvi 205w
The Garmin Chargers use a 1A 5x20mm glass fuse in the tip.
The DC output of the charger is +5VDC @ 1A. The 1A rating is the max rating and your Nuvi should draw less than 1A under normal conditions.
You would not want to put a 3A in there because if there is a short in the Nuvi, you want the fuse to blow quickly. A 3A fuse is too high in value.
- Jim
SHARCNET-USA
Sep 09, 2009 | Garmin nuvi 205W GPS Receiver
GPS charger of my car is not working.
first check and make sure the socket in the car is getting power, like trying your phone charger or something similar. if its not, locate the fuse in the car and see if its ok. if its ok check the fuse for the charger, most are in the tip that gets plugged in to the car. most can be removed by screwing the tip off. if the fuse is ok, then there is probably a problem with the gps.
Sep 02, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Tomtom fuses
Take both the charger (which should have a output rating on it) and the blown fuses down to Radio Shack, Jack. They'll help you out.
May 30, 2009 | Tomtom ONE XL GPS
Car charger fuse
The fuse is just inside the tip that plugs in the car lighter. You screw it off and out comes the fuse. As for the fuse you can go to any local electronics store with the fuse that you get out of the charger and ask if they have it.
Feb 05, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin (010-00583-00) for nuvi 750/760/770 Logo
43 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
