Wont run windows at all. Says: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
Does not boot up to Windows. First BIOS screen with F2 and F12 options, then immediately to "Enter Current Password:?" in blue box. After password and pressing "enter" it goes to black screen for approx 10 seconds. Then: Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM . Then two lines down it says: You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM. Select 'r' at the first screen to start repair. The F keys do what they should. F12 goes to password, then to BOOT Manager. Option 1 or 2. IDE O or Network Boot. Option 1 goes back to the ERROR screen \WIN\SYS32\ etc. Setup utility has codes and properties except Asset Tag Number.Main screen has all options filled with options.
  • Computers & ... Master
  • 787 Answers
You have a corrupt registry and it needs to be replaced.
Doing a System Restore will do this. Since you cannot run it from the hard drive, you will have to boot from a Windows DVD.
Here is the procedure
Running System Restore in Windows 7 from your Windows Disk gHacks Tech News
You did not specify which version of Windows you have so I just picked W7 as an example. If you need more specific instructions, you need to give more specific information.
Here is an explanation of System Restore
System Restore Wikipedia
Posted on Mar 20, 2017
2 Suggested Answers
nyilasrobert
  • 627 Answers
SOURCE: I have an Evesham Axis
It is a registry problem.
Follow instructions from this link:
Posted on Sep 07, 2010
Computer repair
Some how you have entered the bios.(either by hitting F1, F2, F12, for the delete key while in boot) simply restart your computer and everything will be fine. 3_31_2014_4_39_12_am.png
Mar 27, 2014 | Computers & Internet
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Saying:/windows/system32/config/system is missing or corrupted n i dnt now how to fix it wut link exactly do i have to download to my usb to fix it n wut r the steps?
Assuming it is windows XP here are the steps to fix that error:
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:md tmp
My YouTube Channel
Click Here Live Tech Support
May 03, 2013 | ASUS Eee PC 2G Surf Notebook
I have a dell optiplex GS260. It comes on to the a black screen stating windows is unable to start properly, the options are to start in safe mode, with command prompt, last known working config + start...
Did you boot from disc by pressing F12 when you see the logo and select boot from CD? I would suggest you to enter system setup by pressing F2 and check which one is the option choose for your hard disk or HDD if it displays like that. Make sure it says single SATA or IDE disk. If you are not sure where to see, you may choose to restore the default setting of BIOS there. Then reboot. If the problem persists, you can plug the hard disk to another computer and backup the data. I don't see any restore to factory default option for this model. So you can format this hard disk on another machine after the backup and then reinstall the operating sytem using your disc. Try to boot with F12 and choose boot from CD then reinstall it from the scratch. Quicker than check all the details.
Here is a link where you can see which drivers to download from Dell's web site.
http://answers.yahoo.com/question/index?qid=20100519170911AAzAle6
Mar 14, 2011 | Dell OptiPlex GX260 PC Desktop
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
Toshiba laptop problem
boot your laptop from a xp cd and select repair option
Sep 30, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
