No picture on dvd player
I have a pioneer dvd player and a Sharp TV When hooking up the dvd the picture is the only thing that doesn't work. How do I fix it?
  • 3 Answers
SOURCE: magnavox mwd7006 dvd player hookup
How can I hook my Magnavox MWD7006 player up to a entertainment system. So far sound is playing in Stereo (3 speaker) format instead of (six speaker) format or Db5.1. Any ideas? I used a s-video cable to connect.
Posted on Jan 17, 2008
Mrsmiley
  • 54 Answers
SOURCE: Only voice no picuter while playing DVD
make sure the video cable is plugged in correctly, or if it is damaged.
Posted on Feb 12, 2008
praky16
  • 744 Answers
SOURCE: DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
Posted on Jan 21, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
SOURCE: I have connected my Bush DS-A332B dvd player to my
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Posted on Dec 28, 2009
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
We are trying to hook up our wii console how do you get it to work. TV says invaild scan freq.
You have to hook it up to a standard Yellow/Red/White RCA jack. If it doesn't work on one, try another. Make sure you're on the proper input you hooked it up to on the T.V. If this doesn't work, try hooking it up to a different T.V. to rule out the Wii as the problem. Try hooking up a DVD player to the same RCA jack as the Wii was on the Hitachi. After all of these troubleshooting methods, you should be able to get your Wii properly hooked up.
Jun 24, 2011 | Hitachi UltraVision UT47V702 47 in. LCD TV
Can not hook my hdtv phillips tv to my dvd and
That is because your player does not support an HD signal and cannot complete the signal from one system the other.
Nov 28, 2009 | Pioneer DV-563A DVD Player
I have a dvd player that I am trying to hook up to a sharp tv model number 25L-M100B. This tv don't have the necessary ports inthe back to plug dvd or anything up to it. It does have 2 in the front of
Hook the dvd player up to the front inputs usually a yellow and a red or possibly a yellow red and white depending if the TV is stereo or not.
Then on your remote, it the INPUT button and take it to "VIDEO 1" while your dvd player is on and you should get a picture.
Make sure not to mix the cable colors.
Yellow is video
White Audio
Red Audio
A lot of times there is only either white or red and not both. This is just Mono sound, it works, just not "stereo" sound.
Jun 01, 2009 | Televison & Video
My Sharp 42" LC42D85U tv 1 month old no picture or sound
i would take it in and have it repaired while its got a warranty on it...or take it back to the store you got it from and ask them to replace the set.
Feb 01, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Not getting a picture on my sharp 37' lcd 1080p tv
Not sure if you still need help but I will suggest a few things if you have not solved the problem or returned the unit.
Have you tried connecting it to one of the other HDMI inputs?
Have you also tried using the component video out from the Blu-Ray to one of the RCA inputs on the TV to see if the player is working at all? Is there another TV that you can connect it to, to test the player?
Without knowing the model of TV I am limited to solutions I can suggest. Try those and if you need more help, let me know.
Cheers
Dec 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
DVD PLAYER
what kind of dvd player is it, is it for your home? car? and what kind of tv is it goin to? get back at me, jason
Dec 28, 2007 | Sharp 25H-M60 TV
Hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
Nov 24, 2007 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
Oct 03, 2007 | Pioneer VSX-81TXV Receiver
Help with my tv
some tv's dont come with rca jacks, what u can do is run your rca's through a vcr and then the vcr to the televison u can do it that way, or take and buy this thing they carry at radio shack, it is a devise that you can hook your dvd player to a junction box that hooks into the same place as a vcr would in the back of your tv, hope this helps jason
May 14, 2007 | Sharp 25H-M60 TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
