Question about Amana ASD2628HE Side by Side Refrigerator
Refridgerator side is freezing while set to the lowest setting
The manual suggests that it could be the condenser coils are dirty and recommends cleaning them with a vacuum cleaner, which I did.
I found suggestions online that it could be a defective thermostat, a leak in the refrigerant system, a defective air damper, or cold air migration from the freezer.
I found a guide for troubleshooting a refrigerator's thermostat, that is not aimed specifically at this model. I've been trying to locate a repair manual online to help me more easily locate the thermostat in this model.
Any help with a repair manual or schematics on this model, would be great.
Also, any other suggestions for sorting out what is wrong and fixing it.
This did happen upon plugging the unit back in after a cross country move.
    Problem Solver:
  • 9 Answers
Usually the most times a thermostat will go will be upon moving ref to different location or unpluging it and repluging back in later would go with replacing thermo. hope this helps
Posted on May 22, 2009
The refridgerator and freezer are failing to maintain temperatures. The light for the refridgerator temp. is blinking constantly. Both sides continue to raise in temp. regardless of where the setting is...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Samsung RS2630SH Side by Side Refrigerator
Ice cream is not freezing in top freezer compartment - what should cold control be set on - i do not have very much in the refridgerator - is"1" coldest setting model is rrtw18vabw
Refrigerator
heatman101
Dec 12, 2010 | Haier Refrigerators
The freezer on my hotpoint side by side is barely cooling and is above freezing temperature. The refridgerator side is just fine. What could be wrong with the freezer side?
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 14, 2010 | Hotpoint Refrigerators
My refridgerator is not getting cold and the
heatman101
Jul 31, 2010 | Hotpoint FFU00 Side by Side Refrigerator
Side by side refridgerator about 4-5 years old coil in freezer getting too hot and melting things.
Hi!!
A warm condenser is usually a sign of:
Temp. control for freezer set too low.
Timer switch defective
Defective Thermostat
Low refrigerant
Faulty compressor, capacitor or thermal switch
Condenser Fan at bottom back or unit not working.
Condenser clogged up or dirty (air not circulating thru it)
Due to the equipment and expertise needed to repair the unit, I suggest to call a refrigeration technician.
Don't forget to rate this post!! Good Luck!!
Jun 28, 2010 | Frigidaire FRS26F4C Side by Side...
Freezer set to lowest setting and ice cream still very soft. The fridgerator set to the highest setting no coolder 40 degree's
Since it is a shared refrigeration system I would suggest lowering the refrigerator setting a bit. Be sure the door gaskets are in good shape and not leaking. Try placing a piece of typing paper under the gasket and closing the door, it should stay and require a little effort to remove. Try this all around. Another possibility and probably he real problem is the condenser is plugged and or the condenser fan is not operating properly.
Good luck,
Gilshultz
Dec 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refridgerator side not cooling. No air movement.
vent clear but vent opening arround vent frozen or coil is frozen eithor way you probably need a thermostat and a timer
Jul 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Refridgerator is not cooling and freezer is not freezing
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
6reuud
Jun 22, 2009 | Frigidaire FRS26R4A Side by Side...
Condenser icing up
i would suggest the evaporator heater or thermal fuse (if applicable) has failed.
Aug 20, 2017 | Frigidaire FSC23F7D Side by Side...
Refridgerator freezing food
dm, I'm not sure if the thermostat is mechanical or electronic. Assuming mechanical...and I do...turn it to the lowest number...does it turn off? If this works properly, the problem is likely not the control. Does the compressor turn off at any time? If not after an hour or so of operation, the stat could be defective. That's my first guess. Oh, have you made sure that you don't have the ducts in the freezer blocked? The would deflect too much cold air to the fridge section.
Next, defrost the unit and clean the condenser coils. This will help the unit work properly. Then, wait awhile with the unit off. Meanwhile, access the compressor in the rear of the unit. Find the largest pipe coming out of the compressor. Turn the unit on. The largest pipe should frost and then, in about 5 minutes or so...either cause condensation or dry out. If neither happens and the line is either not COLD to the touch or frosty, you're low on gas. If the unit is less than 5 years old, you may get warranty coverage on the sealed unit from the mfgr. Believe it or not, too little gas will cause freezing in some cases!
Nov 28, 2007 | Kenmore 53212 / 53214 / 53219 Side by Side...
Amana ASD2628HE Side by Side Refrigerator Logo
146 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
