Question about Sportcraft Sport & Outdoor - Others
Assembly manual missing - Sportcraft Sport & Outdoor - Others
My 2005 Pontiac Bonneville GXP will not shift into 4th gear I was to it was a fourth gear band but is that the only problem that will cause itI'notto shift into 4th gear
Which transmission does yours have 4T65-E or 4T80-E ?
4T80-E
No Fourth Gear
Checks
Causes
1-2 Shift Solenoid Valve
Inoperative
Debris
Pinched wires
3-4 Shift Valve Bore Plug
Misassembled
4th Band
Burned, slipping, missing
4th Servo Cover
Cracked
4th Servo Pin
Broken, seized
4th Servo Piston
Damaged
4th Servo Seals
Rolled, cut or damaged
4T65-E
Slipping or No Fourth Gear
Slipping or No Fourth Gear Checks
Cause
DEFINITION: A large engine RPM increase is noted in fourth gear, Drive range, with little or no vehicle forward speed increase. First, second, and third gear operation are normal. Shifts into fourth gear are soft or do not occur. Fourth gear ratio is 0.705:1.
Automatic Transmission Fluid Level
Low fluid level
Transmission Main Line Pressure
Low transmission main line pressure
Oil Filter Assembly
• The oil filter assembly (100) is missing, plugged, or damaged.
• The oil filter seal assembly (101) is missing or is damaged.
Control Valve Body Assembly
• The 3-4 shift valve (362) or the 4-3 manual downshift valve (360) is stuck or binding.
• Debris is found in the passages of the control valve body (301) or of the control valve body spacer plate and gasket assembly (396)
Case Cover Assembly
Distortion or damage occurs at the manual valve (404) or at the case cover (401), causing PRN oil leak.
Driven Sprocket Support Assembly
A plugged third clutch oil passage in the driven sprocket support assembly (609)
Fourth Clutch Assembly
• The clutch plates (500-502) are worn, damaged, or misassembled.
• A missing or not seated fourth clutch spring retaining ring (601)
• A damaged spring assembly (602) or piston (603)
• Worn or damaged fourth clutch piston seals (604, 605)
Third Clutch Sprag Assembly
• The sprag (720) was misassembled or backwards on the inner race (661).
• A damaged third clutch sprag assembly (653, 661, 719-721)
Dec 06, 2015 | Pontiac Cars & Trucks
Where can i get Outsunny Grill Canopy assembly manual?
if you call the company that made it they should send you all the parts and a manual free of charge .
Oct 26, 2015 | Sport & Outdoor - Others
SIMMONS JUVENILE PRODUCTS 5017
Products America has parts and instructions manuals for many different manufactured cribs. Please review our website www.productsamerica.com to determine what hardware you are missing. You can also email us at parts@productsamerica.com for the assembly instructions.
Apr 08, 2012 | Simmons Mattress Crib 'n More
My '99 Silverado 1500 Z71 has been an awesome dependable truck with over 225000 miles. But we've suddenly lost the reverse gear. The drive gears work fine & the tranny fluid is fine so what would cause...
No reverse, here are few things you can try before needing to take it to a tranny shop. The 4l60e trans is a fully electronic trans. And being so the problem could be as simle as the reverse shift solenoid has shortted out. Along that same line the reverse valve could be stuck and or the little screen that is attatched to the mid plat could be clogged and in order fix this problemyou need to drop out the valve boby and for the most part rebuild the reverse circute.
Now for the hard stuff. Other problems you could look at.
imput housing assembly - 3-4 apply ring stuck in applied position.
- forward clutch not releasing
- turbine shaft seals missing,cut or damaged.
manual linkage - not adjusted
oil pump assembly - retainer and ball assembly missing or damaged.
- stator shaft seal rings or ring grooves damaged.
- stator shaft sleeve scored or damaged.
- revers boost valve stuck, damaged or misassembled.
- cup plug missing.
- restricted oil passage.
- faces not flat.
- converter clutch apply valve stuck.
valve body assembly - 2-3 shift valve stuck.
- manual linkage not adjusted.
- spacer plate and gaskets incorrect, misposition or damaged.
reverse input clutch - clutch plate worn.
- reverse input houeing and drum assembly cracked at weld.
- clutch plate retaining ring out of groove.
- return spring asembly retaining ring out of groove.
- piston deformed or dished.
- seals cut or damaged.
- retainer and ball assembly not sealing.
- restricted apply passage.
lo and reverse clutch - clutch plates worn.
- clutch plate retaining ring mispositioned.
- porosity in piston.
- seals damaged.
- return spring assembly retaining ring mispositioned.
case - cover plate gasket missing or damaged.
- cover plate not torgued correctly.
- porosity.
now thhis came from my 4l60 service book.
hope this helps
Thank you for using fixya and be safe
Jul 04, 2010 | 1999 Chevrolet Silverado 1500
I'm looking for an owner's manual for the MTD OEM 190-180 twin bagger. Mine is missing some small parts and the manual. Most of the parts are there, but evidently a couple of small brackets and the bolts...
You can download a user manual & parts manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers from under the seat.
Jul 16, 2009 | Arnold Corporation Twin Bag Collect System...
Assembly instructions were missing from box for popcorn maker ccp509
Here is the direct download link for the CCP-509 instruction manual (PDF file):
http://www.nostalgiaelectrics.com/manuals/CCP-509.pdf
However, the Assembly Instructions for the (nearly identical) CCP-200 are better (PDF file):
http://www.nostalgiaelectrics.com/manuals/CCP-200.pdf
Jun 21, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
Sport & Outdoor - Others Logo
80 people viewed this question
Top Sportcraft Sport & Outdoor - Others Experts
Are you a Sportcraft Sport and Outdoor - Other Expert? Answer questions, earn points and help others
