F1 chrony instructions - Computers & Internet
Summit error code F1 ..what problem
Shinning, Unplug your appliance,wait 10 minutes and plug back in to see if error goes away. F1 could mean a defective touch control pad. You may have to find a good repair Tech. to diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix an F1 Error On Kenmore or GE Range
Range Stove Fault Codes
What does the F1 error code on an Amana oven model number AOCS3040ww mean...
Summit Commercial TTM7212KW WTM7212KW Gas Single Oven f1 beeping Questions
Jul 12, 2016 | Kitchen Ranges
What does the f1 mean
Hi Mary Lynn, I don't know if this will be useful but try searching online for "error code f1". If you get a hit on applianceaid.com follow the link and there are instructions which you may find useful.
Jul 11, 2015 | Kitchen Ranges
Whirlpool error code f1
F1 error usually signals a problem with the control board. However, there are a few other things you can try before spending money on a new control board
To remove the error, press Pause/Cancel twice. Unplug the machine for 2 minutes and then plug it in. Select a cycle and press Start. In some cases, this will reset the F1 error.
If your machine is under warranty, you should of course contact Whirlpool and they should repair it free of charge. Even if it's out of warranty, note there seem to be a lot of people who experienced F1 errors on Whirlpool washers and there has been a recall of some models. You can contact Whirlpool and see if your model is one of them.
If this doesn't work out, here is what you can do. The reason for the error can be blockage inside the pressure switch hose. You should check the hose for blockage and there are instructions online on how to do it. If the hose is fine, you should then most probably replace the control board. It's an easy repair. Here are the instructions on how to check the hose and how to replace the control board: Whirlpool F1 Error
Hope this helps. Let me know if you have any other questions
Jan 26, 2014 | Whirlpool Washing Machines
I have an IBM Think Pad type 2373. whenever I turn the computer on I get an error: 0210: Stuck Key 01 It says to press F1 to fix it, I do this and nothing happens. Can you please help me fix this?
F1 may appear as a secondary key on your computer. When the error message starts, try first pushing the 'Fn' key (near Ctrl), and then clicking the F1 button. Then you can follow your computer's instructions to fix the problem.
May 02, 2011 | Computers & Internet
Setting alarm in F5015D F1 series watch
ypu can get a set of instructions by going to their web site (www.jacqueslemans.com).
On the left yu will see a menu, click on "instructions/catalogues" and you can download the instructions for your watch.
Feb 02, 2010 | Jacques Lemans F1 Analog Digital Watch
F1 error on cabrio washing machine
Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2
  • I called Whirlpool 1-800-253-1301 today 10/15/08 and they said the F1 issue is now under a recall.
  • Whirlpool scheduled a repair service -during our phone call- to repair this under a 'recall' & at 'No Charge' to me.
  • I'll let you all know how it goes after the repair..
Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore Kitchen Ranges
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Computers & Internet Logo
David Payne
David Payne
