Question about Craftsman Air Tools & Compressors
Craftsman air compressor bearing flywheel
I have a Craftsman Model # 919.153130 (919.153131) air compressor that has bearing flywheel issues. The bearing flywheel has lost the shaft key from the motor shaft. The bearing flywheel rubs against the the motor housing and the flywheel slips while the motor shaft is turning. Is there any type of buffer/washer/bearing protection between the motor housing and the bearing flywheel? How do I get a new motor shaft key to fit into the bearing flywheel or am I missing something else? I have looked at the parts schematics and see nothing about a flywheel/motor shaft key, nor do I see any type of flywheel/motor housing buffer protection. Help, I don't want buy a new compressor after this one has served me so well for many years. Thanks
    Problem Solver:
  • 13 Answers
Your local hardware store should have one. The model number will probably not help; you will need to measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
Hope this helps.
Posted on May 22, 2009
And that most likely burned out the engine bearings.
Sep 07, 2016 | Craftsman Air Tools & Compressors
Flywheel on 5hp generator keeps freezing up
sounds like bearings on your krank are going out
Jul 01, 2012 | Craftsman Briggs & Stratton Portable...
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Sources of noise from craftsman oil free compressors (could be Made by Campbell Hausfeld or Porter Cable) include loose fan, failing bearing/s on the piston rod and housing, failing seal ring on piston, air filter intake and loose motor mounts. With the housing cover off, check the fan blade for cracks or loose screw. Turn motor by hand till the piston is at top of stroke. Examine the cylinder for scratches close to top. If scratched, air is leaking past vinyl ring making noise and causing longer fill time. If everything looks ok, suspect noise coming from bearings. Hard to tell if bearings are failing by looking at them. I have seen many failures of the piston bearing on the crank (fairly easy to change, I use alternator bearing from auto parts ) , however, the bearing in the housing just behind the crank bearing is much harder to replacable. Good luck with your fix-it project.
Jun 11, 2012 | Craftsman Air Tools & Compressors
12 gal 2hp instruction manual
You didn't give your model number so here's a possibility: If it's vibrating that much it's usually a good indicator the air pump connecting rod is broke. If it's been in storage it's possible the oil evaporated enough or it didn't have enough in it that it didn't lubricate the con-rod bearings. It would have started the first time but as heat built up in the bearing areas it could have seized up when it was shut off or broke when it tried to restart. You'll have to take the air pump apart to verify what's broke and what's damaged and what has to be replaced. Most Craftsman parts are only available through Sears (www.searspartsdirect.com).
Mar 05, 2012 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have an older model Sears Craftsman air compressor, 1 hp, 100 psi, twin cylinder. Model 106.154541. The compressor comes on fine, but when the pressure gets to 40 psi or so the belt starts to squeal,...
Could be the bearing in the pully wheel rides on,,not the belt,,,While its running spray some belt dressing on belt to see if its the belt,,,while running get a can of wd-40 with long nosel attachment and spray the armeture that tures pully when you spray it if its the bearing it will stop makeing noise momentarly, than come back again than as you spray it it will stop as long as you spray. BE CAREFUL. Bearings wear out when old,,,like us!
Mar 11, 2011 | Craftsman Air Tools & Compressors
CRAFTSMAN Air compressor Model: 919167450. IT'S GOT A LEAK" SO FAR SEEMS LIKE AIR ESCAPING AT CONNECTION OF COMPRESSOR TO TANK. THE COMPRESSOR THEREFORE DOESN'T SHUT OFF COZ PRESSURE LIMIT(PSI) IS...
Manual:
http://www.managemylife.com/mmh/owner_manuals/8336/CRAFTSMAN-Air-compressor-L0809089
Schematics:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0040151-00001.png
Parts ordering:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919167450/0247/0703000/P0040151/00001?blt=06&prst=&shdMod=
Jan 08, 2011 | Craftsman Air Tools & Compressors
Broken cog on compressor motor 919.166440
Below is a link where they have a variety of parts for smaller craftsman compressors.
I didn't see an exact match for your model however I think if you contact them they will probably be able to help you out. I'm sure that motor/pump model was used on several different models.
Hope it helps.
http://www.mastertoolrepair.com/craftsman-sears-parts-portable-compressors-c-271_535_537.html
Nov 16, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I need to replace the connecting rod,cylinder sleeve,and eccentric bearing assembly on a craftsman model no. 919.165050
Your compressor is made by Porter Cable. You can use sears parts or takes your old parts to a local Dewalt service center and they will match them up with replacements. You can save some money on the bearing by using a generic. Universal bearing number will be found on the dust shield. Most likely the sears part numbers will be the same as porter cable. Dewalt service center will help you with other questions and or instructions. Good Luck!
Oct 10, 2009 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
380 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
