Question about Sharp LC-26DV12U 26 in. LCD TV/DVD Combo
Lost picture. Sound works but just a black screen
It happened a few weeks ago but the screen returned now it is just black, no color or activity whatsoever
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Sound no picture
Like stated before--May be another bad blub, especially if you used a generic or Neolux one. A phillips bulb WILL work right. Mits sets do NOT like generic bulbs !!
Apr 05, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
My sanyo vison hdtv lost picture maybe a year ago then after sitting all this time i plugged it in and it worked like new then thismorning it lost picture again... screen is black with a little tint of...
This is most likely going to be a color wheel. I would recommend checking on the color wheel first. If this is a dlp tv it could also be a lamp that went out.
Jul 23, 2012 | Sanyo DP42849 42 in. HDTV
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
Not Supported Mode
Sound as if the digital board has failed, Samsung p/n# Bp94-00385a
Bill
Apr 02, 2008 | Samsung HLN5065W 50" Rear Projection...
No picture, sound ok
Rca has been known to have bad solder joints in the deflection circuits. Usually around the flyback and transformers.. check it over real good. Just be careful as you can still get shocked after the powers removed the capacitors and picture tube will hold a charge in them.
Jan 21, 2008 | RCA F36649 36" TV
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Sharp LC-26DV12U 26 in. LCD TV/DVD Combo Logo
18 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
