Question about Samsung WF448AAW 4.5 cu. ft. Front Load Steam Washer
Lost power for 5 days. washer will not power up now.
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Roper washer don't start
That is still under warranty, you have done all that you can within reasons. Call Lowes.
Jan 24, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
Washer keeps pausing and now wont wash
Shelly,
I see that you're having trouble with your washer pausing and now not washing. I suggest giving the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If you are still having the pausing and no washing issue it might be something to do with the control board or possibly something else. I would suggest either calling the manufacturer or a local authorized technician. This way they can possibly troubleshoot with you and get this issue resolved.
-Best Regards-
Jan 17, 2014 | Frigidaire Affinity FAFW3801LW 27"...
Washer lost power right at the end of a load. not breaker
If you have no power and you have power to the outlet, then you will need to replace the control board. Here is the board to order.To replace the board, remove the back cover on the console, the board is located at the back of the timer.
The part comes with a 365 day, any part, any reason return policy.
Nov 17, 2012 | Maytag Atlantis MAV6000 Top Load Washer
We had a power failure the other day and now our washer filled with water and won't spin. What can we try?
have you tired resetting it by unplugging it for 5 minutes? if that doesn't do it then it is time for a washer repair technician to look at the problem.
Mar 23, 2010 | Maytag Neptune MAH6500A Front Load Washer
Frigidaire top load washer that keeps shutting off
i canty be 100 percent sure
without the model
but it sounds like you motor is trying to start but for whatever reason is cutting out on the overload. Meaning it gets hot,,,and shutsd it self off to save it self
ther ecould be alot of reasons for this,,, far to many to type here,,,
with frigidaire it could be a bad motor capacitor, or a bad start winding on the motor.......
or a simple as a sock between the tubs preventing the tub from truning
sorry i cant be more help
but figured you should have some sort of answer to at least5 investigate
Oct 28, 2009 | Washing Machines
Ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Jan 04, 2009 | Zanussi IZ141W Front Load Washer
Samsung WF448AAW 4.5 cu. ft. Front Load Steam Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
