Question about Coffee Makers & Espresso Machines
Grinder wont grind anymore - Coffee Makers & Espresso Machines
2 Suggested Answers
  • 270 Answers
SOURCE: Grinder on Cuisinart Grind and brew does not work
Have you ever heard of the saying: A penny on the rail will prevent a locomotive from starting, but a locomotive will run over the same penny at speed.
This is what I think you have here. A coffee bean is preventing the blades in the grinder from grinding. Just like a garbage disposal, turn the blades (UNPLUG THE MACHINE) backwards to free up the blocked or binding blade, then try again. Depending on the age of the unit and frequency of use, the grinder motor may have failed and needs replacement.
Good luck.
Posted on Sep 26, 2010
Grinder not grinding?
Go and purchase another grinder? Motor no good anymore or the button is bad! Thanks for using FixYa! John
Feb 23, 2011 | Computers & Internet
Grinder on Cuisinart Grind and brew does not work anymore.
Good luck.
Sep 26, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Our bean grinder has stopped grinding. It spins but the beans do not grind. The machine works fine on the ground coffee option.
Did you put water in the grinder by mistake? If the grinder is wet it won't grind anymore,have to cleaned the blades physically .
OR are you using the beans from the fridge? It's a NO NO.
Jul 30, 2010 | Saeco Magic De Luxe 30092 Espresso Machine
Coffee grinder will not turn on
I recently had this same issue - it turned out that the lock switch no longer engaged because the spring came out of alignment after the unit was dropped. Chances are you have a similar issue. You can test this by using a small screwdriver to press down on the safely latch and then pressing the ON/OFF (careful of the blades!!). then you can easily fix it.
Dec 26, 2009 | Hamilton Beach 80355 Custom Grind Coffee...
How can I ajust my machine the coffee is coming out weak and watery I don't get that creamy,strong coffee anymore
HI
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Oct 23, 2009 | Spidem Trevi Digital Coffee Maker,...
Beans are too oily
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Aug 06, 2009 | Bosch Benvenuto B30 Espresso/Coffee Maker
Coffee beans are not fine
Have you replaced your blades recently? If you will call contact customer service, we can send these out to you free of charge.
Mar 08, 2009 | Bunn Coffee Grinder
Grinder starts up but wont grind..nothing happens. one week old
I think this might be because no beans have gone down into the mill. There is a definite difference in sound when it is actually grinding beans. Try emptying the beans out, set it to the coarsest setting, put the beans back in, shake the thing a bit then turn it on.
Jan 17, 2009 | Krups Burr Coffee Grinder
Saeco Vienna De Luxe not transferring grounds to brew group?
Make sure there not comming any damp into the grinder and the grinder is dry. If there was some damp in the grinder then you have to clean the grinder.
Aug 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
11 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
