Question about Sylvania Televison & Video
LC321SS9 sylvania can not connect to laptop with hdmi error reads "not supported format"
I tried to connect the tv to the laptop with an hdmi cable but the sylvania tv says not supported format
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
Posted on Feb 17, 2009
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
SOURCE: My Time Warner cable Remote will not program to my TV.
I had the same problem, so I followed these steps and it worked!
1) Turn on TV.
2) On the remote control, press TV once (it will blink once). Then press and hold SETUP until the TV key blinks twice.
3) Enter 9 9 1, (the TV key will blink twice).
4) Aim the remote control at the TV & press POWER once.
5) Press & release the CH+ key continously (you may need to press it more than 50 times!), then stop when the TV turns off.
6) Press POWER. The TV should turn on, then immediately, press SETUP to lock in the code.
Posted on Aug 22, 2009
budmrtn
  • 11361 Answers
SOURCE: My LC320SLX Sylvania TV displays the message
You are getting that message becuase the MAC video resolution is too high for the TV handle, you need to lower your MAC video resolution to the native resolution of the TV, read your manual to find out what it is.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 08, 2010
SOURCE: PS3 hdmi generates a not supported format error
your ps3 is set to work on a 1080p tv you can change the pixel setting on your ps3 by holding the power button down while youe console is running until it turns off let go and hold your power button down again when your console turns back on your tv wil ask you about the hdmi device its found unless you failed, good luck n00bs
Posted on Dec 07, 2010
LC321ss9 model. How do I get the TV to go to the Satellite mode?
keeppushing that button and it will go back to the starting point . my tv has cable/satelite /antenna/dvd/vcr jsu chose the option that sounds right . can always go back and try other s
Jan 26, 2015 | Sylvania Televison & Video
Restart and blue error screen
Get a new HDMI Cable as that HDMI may have an internal short or disconnection
Aug 24, 2014 | Computers & Internet
I am trying to hook up my computer to my lc321ss9 b tv. I hooked it up to the VGA port and it says format not supported?
your screen resolution probably exceeds that of the tv.
try playing with your screen resolution.
May 02, 2011 | Sylvania LC-321SS9 32 in. LCD TV
I would like to use my Sylvania LC320ss8 Flat screen tv as a computer monitor but when I plug in the monitor plug the screen on the tv says format not supported. My operating system is Windows 7 and...
If you have connected the TV to the computer with a VGA cable, what resolution was your previous monitor using? You may need to change the resolution or refresh rate with your regular monitor attached. This TV has a native resolution of 1366 x 768 .
If you are connected via one of the HDMI ports, check the specifications for your TV. Then try using the VGA output. Not all TVs support a computer signal over HDMI. Unfortunately, I can't find the LC320ss8 at the Sylvania Support site: http://www.sylvaniaconsumerelectronics.com/ . If the model number has an error, click on Downloads and enter the correct model number.
I hope this helps.
Mar 31, 2011 | Sylvania LC320SS8 32 in. LCD Television
My LC320SLX Sylvania TV displays the message "Format not supported" when I plug in my new Mac Mini computer. I am using HDMI cables to connect.
Aug 08, 2010 | Sylvania LC320SLX 32 in. LCD TV
PS3 dont work
Go through setup on your PS3 with a normal AV cable and un-check the higher resolution boxes (1080p and down) one at a time, unless you know specifically what resolutions your television supports. After un-checking, plug in the HDMI cable and see if it fixes it. Basically, you need to set the PS3 to a supported format for your television.
Jan 31, 2009 | Sylvania LC195SL9 19 in. LCD TV
Sylvania LC321SS9 remote code
I have the sylvania LC321SS9 tv and a atlas dvr1056 remote code 1864 works great with all functions!
Jan 14, 2009 | Zenith ZEN450 Remote Control
LC321SS9 remote code and cox remote can not find universal code
I have the same TV and the same problem. I exchanged the Cable remote for a new one and did the auto search. (hold the tv button/Sel key then channel up key) It worked with the new remote. I believe the code is 121
Dec 22, 2008 | Sylvania LC320SL8 Television
Televison & Video Logo
70 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
