Question about Ariens Snow Blowers. Compact 24 in. Two-Stage Electric Start Gas Snow
Snowblower sheer pin for one blade is gone but the cutter won't spin so i can't line up the holes to replace sheer pin
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 91 Answers
Could be the remaining piece of sheer pin is binding the auger at the shaft.
Try rocking auger back and forth till it works free.
Disconnect spark plug first
Posted on Apr 09, 2015
    Sergeant:
  • 416 Answers
If auger wont spin heat it up a little
Posted on Feb 02, 2015
How to replace shear pin horizontal blades spin free motor won't drive them
Look close to the middle of the auger. you should see small ( 1/4") holes where the shear pins were. Just line up the holes from shaft to Auger and put new Shear pins in there. Sometimes they look like Clevis pins and sometimes they look like a simple 1/4" bolt and nut
Jan 04, 2016 | Garden
How do I check mower for compression. when i pull, the blade feels like its in free spin. no noise, and sheer pin is intact
You can certainly use a 'compression tester", like mechanics use on car/truck engines. They're not really expensive, but the test will take two people, one to pull the starter cord, one to hold the tester to the sparkplug hole.
May 24, 2015 | Garden
How to change shear pin
With the motor OFF, the shaft shouldn't rotate, so you should be able to rotate the auger by hand until the holes line up.
Mar 01, 2014 | Craftsman Sears Snow Thrower Manual Model...
Auger in snowblower blower does not turn
Check to see if cable is still ok and not broken. Also adjusted.
Feb 10, 2013 | Craftsman Snow Blower / Snowblower Bottom...
Could you please explain how I change from the nylon line trimming head to the metal cutting blade on my Echo brush cutter model SRM-22GES? Thanks for your help.
To change the head on the trimmer you will need to turn the trimmer upside down as if you were going to take the head off to restring it, spin the head and look for a slot in the side of the head when you see the slot, keep spinning until you see it line up with a hole in the metal piece the head attaches to. Stick a nail in the slot and hole and turn the head off the trimmer, if I remember correctly the head is backward thread.
Follow the steps backward for putting the brush blade head on the trimmer.
Apr 25, 2011 | Garden
Electric snowblower. Paddle stops when it hits snow. Is there a pin that may have snapped from overload? Belts are good and tension spring seems ok. Thanks!
Yes there are, usually what is called a sheer pin. They are designed to break before anything else is broken. They are found on the auger shaft. You probably can't see them because they are broken and have fallen out. Inspect the auger shaft where you should find holes where they go. Go to a shop or where they sell parts and get the proper sheer pins. If you can't find any, ordinary bolts will work just as well. Install them in the holes you have found on the shaft (I hope). If the bolts are still there on the auger shaft, then there in something else wrong obviously. You say everything looks ok, so that is surely the problem. I hope this helps you even just a bit. Best regards and good luck.
Jan 27, 2011 | Garden
Craftsman Snowblower. One auger is disengaged...turns freely when touched....does not push snow
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
Dec 27, 2010 | Craftsman Garden
Auger blades won't turn
You need what they call a "friction wheel" replaced.
Oct 31, 2009 | Garden
Ariens Snow Blowers. Compact 24 in. Two-Stage Electric Start Gas Snow Logo
113 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
