How to give ip address to workcentre m133 network printer
: You must be a System Administrator to perform this solution.
1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
5. Select [System Settings] twice. The System Settings screen will be displayed.
6. Select [Network Settings]. The Network Settings screen will be displayed.
7. Select [Protocol Settings]. The Protocol Settings screen will be displayed.
8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed.
9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed.
10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed.
11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed.
12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed.
13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed.
14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed.
15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed.
16. Select [Close] three times.
17. Select [Exit]. The machine will reboot automatically.
