Try a new cartridge, they do warp over time. That would be "best case scenerio" worst case is the optic is shot/out of alignment, etc. There should be a reset button on the changer below the cartridge "(@)" small pen sized dimple that can be pushed w/a ball point pen to reset. How old is the unit? it's still in the current lineup. If it still doesn't work, call Alpine USA, give them the serial # if you don't have a receipt for it. They can tell you when it was manufactured to check for warranty status. Otherwise your looking at $100 - $150 repair. They would just swap out the transport. Best of luck!. Hope this helps!
I cant get the cd's to play or eject in my '03 gmc truck(stock stereo). Display reads...
(More)
I cant get the cd's to play or eject in my '03 gmc truck(stock stereo). Display reads ''Initializing'' but nothing happens.Please help.JT
I cant get it to eject cds, play cds or load cds. Says cd error. I was playing the cd when it...
(More)
I cant get it to eject cds, play cds or load cds. Says cd error. I was playing the cd when it stopped and said cd error. I could never get it playing again.
I have a M812 unit that refuses to snchronize with docking station,the docking station will show the...
(More)
I have a M812 unit that refuses to snchronize with docking station,the docking station will show the "Sync 1" light for a short period but then drop out,cannot get both lights on. Have worked way through Troubleshooting approaches as well as rebooting,placinng units next to each other,ensuring line of sight etc
The audio system has a shuffle mode, it only shuffles on each disc individually not between all 6...
(More)
The audio system has a shuffle mode, it only shuffles on each disc individually not between all 6 disks. Is there something I am missing or does it only shuffle on a single disk
I have an Alpine CHA-S634 disc changer. The disc and magazine are jammed and i can't seem to find a...
(More)
I have an Alpine CHA-S634 disc changer. The disc and magazine are jammed and i can't seem to find a way to fix it. The 6th tray is still pushed into the unit along with the disc, thus preventing it from ejecting the magazine. And all I get is CD errors when I try to change discs from the head unit in my dash. If i try to eject the mag it just grunts a little, appears to be attempting to retract the disc and eject the mag, but no results. This is the second time this has happened. I originally had an older non-mp3 Alpine changer that had the same problem that i decided to just replace since i couldn't fix that one either. Seems to be an ongoing problem with alpine changers... The jam occurred when i was changing between discs while driving (in both cases) If you have any suggestions apart from just completely dismantling the unit i would be most appreciative. Thanks PowerLloyd
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
