Question about Motorola Mobility Cellular One Car Phone Mobile Brick Vintage Bag Cell Phone
HOW DO I UNLOCK AN OLD MOTOROLA CELLULAR ONE BRICK THAT'S NOT IN SERVICE?
ITS A 3 DIGIT NUMBER. I ACCIDENTLY PRESSED FCN.5 AND LOCKED IT.
My phone is locked , and now asked me for my Blur account username and password ....but i forgot ....i got the motorola CLIQ
Before you can attain your Motorola CLIQ's unlock code you will need the IMEI number on it. You can find the IMEI number by simply typing *#06# and hitting enter. This number is unique to all GSMphone and will help calculate your unlocking code. Once you have your unlock code you are ready to begun the Motorola unlock instructions posted below.
Here are the steps to unlock your phone:
Unlock Motorola CLIQ (SIM Unlock)
1. Reboot your Motorola CLIQ with an unaccepted SIM card in.
*If the display reads "Enter Special Code", enter the unlock code and press "OK"
*If the display does not read "Enter Special code":
2. Press and hold the * key until an entry box is displayed.
3. Type *, #, 3, 2, # and press "OK"
4. Enter your Motorola CLIQ's unlock code and press "OK."
5. Your Motorola CLIQ should now display either "Completed" or "Deleted"
Jan 01, 2011 | Motorola Mobility CLIQ Cell Phone
My daughter locked my old cell phone with a 4 number code and now doesnt remember what she set it to
Try 1234, or the last 4 digits of the phone number. If this does not work
enter 000000.
If the sim is locked you will have to contact at&t for a code.
Feb 06, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
PHONE LOCK FORGET LOCK CODE
Here is some great source to solve any kinds of Cellular Phones problem.
» Nokia Solution
» Motorola Solution
» Sony Ericssion Solution
» LG Solution
» Samsung Somution
Here is some another Great source to UNLOCK any kinds of Cellular Phones.
» Nokia Unlock Code
» Motorola Unlock Code
» Sony Ericssion Unlock Code
» LG Unlock Code
» Samsung Unlock Code.
Or you could try this :if all else fails.
then:enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and get the
puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted.
Nov 08, 2009 | Samsung Eternity Cell Phone
Accidently hit phone lock and can't unlock it -- default doesn't work 0000
Step 1
Turn on the phone.
  • Step 2 Try to dial any number, and it will tell you the phone is locked. Press "Unlock."
  • Step 3 Once you press "Unlock," you will be prompted to enter the lock code or your PIN number. If your phone is locked and you never entered a lock code, the default lock codes are typically either the last four digits of your phone number or "0000."
  • Step 4 Enter your code and press "OK." Your phone is now unlocked.
  • If this doesnt work, try maybe 1234... And if none of that works, your cell phone service provider will be able to change it for you, as long and you can prove your the phones owner......
    thank you and please rate this answer.. :)
    Sep 24, 2009 | LG VX5200 Cellular Phone
    I dont remember the phone lock code of motorola v3i
    Your phone’s four-digit lock/unlock code is originally set to 1234.
    The six-digit security code is originally set to 000000.
    If you forget your unlock code: At the Enter Unlock Code prompt, try entering 1234 or the
    last four digits of your phone number. If that doesn’t work, press and enter your
    six-digit security code instead.
    Jun 24, 2009 | Motorola Mobility RAZR V3i Cellular Phone
    I cant unlock my phone.
    1.press and hold the end/power 0ff6111.gifkey to turn on the phone.
    2.press the left soft key to select unlock.
    3.enter the four digit lock code.
    if u dont know the code
    check out this site
    http://www.gsmunlockintl.com/motorola-ic602-p-99-m-5.aspx
    thank u.
    Apr 27, 2009 | Motorola Mobility ic602 Cellular Phone
    Need Help to unlock it.
    Press [_] [*] to lock or unlock
    to manually lock your phone
    Press[_] > settings > Security> phone lock > Lock now
    Apr 21, 2009 | Motorola Mobility ROKR E8 Cellular Phone
    FORMAT CODE FOR MOTOROLA L6
    my motorola l6 is keep on restarting when ever i press a key so i thought it might get better to reformat my phone so i need the format code for it.
    Mar 23, 2009 | Motorola Mobility L6 Cellular Phone
    I want to be able to unock my sony ericsson w580i so that i may be able to put my vodane sim or indeed my orange sim card ,basiacally i want ti to be unlocked thanx!
    Step by step instructions:
    1.> Get your cell phones IMEI number. Press *#06# ( 5 key press) and you should see this number displayed on your phone. Note down all numbers except the last two. You will need this when you call your providers customer service to ask for subsidy unlock code. You can also get IMEI number by removing the battery cover and battery. You should see the IMEI number written on a sticker. This number is the correct IMEI number and should match the one displayed when you pressed *#06# on your phone except for the last two digit. AGAIN DO NOT GIVE THE LAST TWO DIGIT WHEN ASKING FOR SUBSIDY UNLOCK CODE.
    2.> Call you cell phone customer service and give this IMEI number. Ask them to give you SUBSIDY UNLOCK code. Subsidy unlock code is 16 digit long number.
    3.> Once you have unlock code, press <**< ( < is left navigation key) key combination ( 4 key press). Select Network to unlock network and enter the subsidy unlock code. Press OK. You will see Network unlocked message displayed. Inputting incorrect unlock more than 3 times will permanently lock your phone to your provider. So beware when you enter the numbers.
    You now have a Sony W580i phone that is unlocked and can be used with any GSM based mobile providers.
    Good luck. Hope it helps.
    Feb 26, 2009 | Sony Ericsson w580i Cellular Phone
    Motorola Mobility Cellular One Car Phone Mobile Brick Vintage Bag Cell Phone Logo
    15 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    D. E. Hev
    Richard Lane
    Vernon Taylor
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
