Question about GE GTL17JBWBS 16.6 Cu. Ft. Top-Freezer Refrigerator - CleanSteel
Ice maker has no power - GE GTL17JBWBS 16.6 Cu. Ft. Top-Freezer Refrigerator - CleanSteel
REPLACE ICE MAKER PART AP4345120
Remove the ice bin. Remove two screws, holding the ice maker and unplug the power cord. Remove the ice maker.
On the new ice maker install the water chute (plugs in) and install the new ice maker.
Mar 13, 2012 | Refrigerators
GE refrigerator is not making ice
There are several types of ice makers with the same model number. Some of my questions may seem over - the - top, but I do not know your level of ability. Do not take offense.
Did this ice maker ever work before, or is it a newly installed maker or a factory installed maker in a new fridge? Have you moved the power switch to on? If yours has an LED power indicator, is it off, blinking or on? Off means there's no power to the maker - you'll need to get the maker powered up before going further (make sure the electrical power connector is mated fully). Blinking means cubes have become stuck in the maker. You'll have to shut the maker off, remove the cubes then power up again. On means it is powered and is working normally. Is the freezer compartment set to maintain a temperature lower than 15 degrees F (-9 C)? The ice maker will not make ice unless the temperature is below 15 F (-9 C). The space under the maker must remain clear of obstructions so that the sweeper arm is not blocked (when blocked indicates a full ice container and will halt ice production until the arm can move freely again). The maker may need as many as 3 cycles (approx 6 hours) before all the air in the ice maker's water lines have been purged completely.
Listen for the solenoid valve to operate. Every couple of hours, this valve should operate and an audible click on and click off heard after a several seconds (as long as set on the ice maker cube size adjustment knob). When this solenoid has clicked on, water should be flowing through the lines and filling the ice maker. If not, there is an obstruction that must be cleared. A dirty or improperly installed filter, pinched line, and even ice can interrupt flow to the ice maker. You might need to remove the ice maker from the freezer to check the water supply line that feeds it for the presence of ice. Melt / clear as needed.
Jan 23, 2012 | GE GSS25LGM Side by Side Refrigerator
Automatic ice maker stopped working, Checked water supply to back of freezer, and the water supply is on. Arm on ice maker seems to be in correct position. there is no water in ice maker. can feel the...
Assuming you have active water supply to unit, either water valve or ice maker is bad. If Ice Maker is sending power to valve during Ice cycle, then valve is bad. If no power to valve during Ice cycle, then ice maker is bad.
Sep 11, 2017 | Amana ARB2557CSR / ARB2557CSL Bottom...
WATER IS NOT GOING TO ICE MAKER. HAVE POWER TO ICE MAKER BUT NO POWER TO SOLENOID WATER IS TURNED ON
If there's not power to the solenoid when the ice maker calls for water, the problem is with the ice maker module or control board.
Sep 22, 2009 | Jenn-Air JCD2389G Side by Side...
I have model 3XART720F02 ART706 TYPE 2055A The water ice distribution area needs cleaning. Can this area be dismanteled
Prepare the Ice Maker For Cleaning
Step1Lift the power located above the ice maker storage tray.
Step2Unplug the refrigerator.
Step3Allow the refrigerator and to defrost. This will melt any large blocks of ice that have accumulated in the ice maker
Clean the Ice Machine
Step1Remove the ice machine storage tray.
Step2Dump any water in the ice machine storage tray.
Step3Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
Step4Sanitize the lines of the ice maker. Consult your manufacturer's
directions for steps to do this, because it's not available on all models.
Reassemble the Ice Maker
Step1Replace the ice machine storage tray.
Step2Plug the refrigerator into the outlet to restore power.
Step3Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
How to Clean an Ice Maker
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 21, 2009 | Whirlpool Refrigerators
We have the Kenmore 106.5703.601 side by side with an ice maker. We lost power for a whole day. The power is back, but the ice maker does not dispense ice. Water is dispensed through the door fine, and...
I think if you unplug the ice maker and remove it from the freezer to let the ice melt and dry out the Ice maker may start working again once you put it back in the refrigerator. If not we will need to check the thermostat inside the ice maker. Try that first and let me know the results. We will get it working I just need you to do this step by step until I locate the problem. But until the ice maker is dried out I cannot see if the thermostat will call for water when plugged back in. Let me know, Sea Breeze
Aug 16, 2009 | Kenmore Refrigerators
Sub zero particles in ice from ice maker
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1 Lift the power bar located above the ice maker storage tray.
  • Step 2 Unplug the refrigerator.
  • Step 3 Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
  • Step 1 Remove the ice machine storage tray.
  • Step 2 Dump any water in the ice machine storage tray.
  • Step 3 Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
  • Step 4 Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
  • Step 1 Replace the ice machine storage tray.
  • Step 2 Plug the refrigerator into the outlet to restore power.
  • Step 3 Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
  • Jul 20, 2009 | Refrigerators
    Ice maker hasn't worked in years. A couple of days ago food below the ice maker was thawed. Today I felt that the ice maker was hot to the touch. Is there anyway to disengage the power to the ice make
    Yes you will need to take the screws that mount the Ice maker to the side of the freezer and unplug the cable plug that is hidden behind the back of ice maker. The only time that element is needed to become hot is the moments before the ice maker drops ice. Thanks, Sea Breeze
    May 15, 2009 | Kenmore Refrigerators
    Ice Maker not working
    Hi!!! your ice maker might have frozen over and gears are stuck..remove your ice maker and unplugg from the frig clean it and all is resolved..
    Jan 04, 2009 | Refrigerators
    GE GTL17JBWBS 16.6 Cu. Ft. Top-Freezer Refrigerator - CleanSteel Logo
    29 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
