Question about Samsung DMT400RHB Builtin Dishwasher
Leaks Leak coming from vent on front door
87 chevy caprice A/C vent not opening
Depends on what is clicking. The engine vac opens blend doors under the dash. It could be one of the vac pots or a blend door is sticking. Normally the hissing noise means you have a leak, but a leak usually does not fix itself.
May 18, 2013 | Chevrolet Cars & Trucks
Air doesnt come out of defrost or fert vents. Only comes out of front vents
One of your gate valve is not opening. You might have a vacuum leak on the gate valve
Dec 03, 2012 | Cars & Trucks
Air flow issue- intermittently blows from wrong vents
This is a common problem on this site.
In your case I would look for a vac leak or a sticky blend door.
Since the direction of air flow changes when you are accelerating, I'm going to guess the blend door or doors are controlled by engine vacuum. There may be a vac leak between the dash and the engine, or the blend door may not be able to move back and forth correctly.
Defrost is the default position when a problem occurs, to make sure the windshield is clear of fog or frost.
Jul 19, 2012 | 2005 Mazda Tribute
LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Jan 16, 2010 | LG Dishwashers
Air conditioning and heating problem
The blend door actuator is vacuum driven. It sounds like you have a vacuum leak. Trace the vacuum lines starting at the firewall in front of the passenger side. With the heater or AC on HIGH and directed at the front vents, listen for a leak or trace the vacuum line back ward to try to find a leak. All the best.
Greg
Jun 22, 2009 | 1999 Ford Ranger SuperCab
AC AIR BLOWS BACK AND FORTH FROM DEFROST TO FRONT VENTS
you have a vacuum leak. Check the vacuum reservoir for a leak.
You can spray short bursts of starting fluid on the vacuum lines to find a leak. When engine revs, that's the leak. Be careful.
Vacuum Reservoir Tank and Bracket Removal
  1. NOTE: The A/C vacuum reservoir tank and bracket (19A566) is located either on or beneath the RH front fender splash shield (16102) .
    If the A/C vacuum reservoir tank and bracket is visible from above in the engine compartment, perform Steps 2 through 4. If the A/C vacuum reservoir tank and bracket is not visible in the engine compartment, perform Steps 5 through 8.
  1. Remove the screws and the A/C vacuum reservoir tank and bracket. 1b32ebf.gif
Jun 14, 2009 | 1988 Ford Ranger
Water leaking into KH laser Hatchback
It could be coming in through the rear door as the rubber might not be sealing properly the easiest way to find the leak is to remove your seats and carpet sit inside get someone to squirt the car round the doors and windscreen air vents.
Feb 25, 2009 | 2006 Ford Laser
Maytag Quiet Series 300 Dishwasher leak
hi there,
the leak may be coming from the door gasket or the door vent.
can you provide me with the complete model # please?
Sep 21, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore Ultra Wash 3 Leaking
Got a possible solution from a brilliant guy named Jake on another website and thought I would post it back here.
"Check the door vent on the inner side of the door, that should just snap out, I have seen those clog and start making more pressure inside to make it leak from the bottom. Jake"
I checked mine and got a nasty surprise. Who knew it could get so dirty.
Nov 01, 2007 | Kenmore 15129 Built-in Dishwasher
Door leak
Br, couple of things you can look for here. Check the vent, you can just pop this out. Sometimes there is a buildup of gunk which will hold water during wash and leak down between the door. There is a seal there, part number 974782. Another thing is to check the upper spray arm for cracks or splitting. This can send a direct flow of water into the vent. There is also a seal at the bottom of the upper spray arm, part number 3376846. I was fooled by a leak like this once, it turned out to be a clogged vent...Catriver..post back.
Sep 30, 2006 | KitchenAid 24 in. KUDS25 Built-in...
Samsung DMT400RHB Builtin Dishwasher Logo
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
