Panasonic viera problems
Controls at bottom of screen seem to be stuck and no picture or sound but power light on
SOURCE: Panasonic Viera TH-37PX8B Green Screen When Turn On DVD Player
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
Posted on Jan 05, 2009
SOURCE: Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash intermittently. While set was in this mode, could not enter menu, change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an overheating issue. But unplugging the Viera and waiting for set to cool made no difference.
I then remembered that this issue popped up the instance I surfed to a particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora, Illinois, USA). I had a hunch that there might be an issue with the signal on the channel that prevented the Viera from properly syncing, so I decided to unplug the antenna cable. Once I did that, the channel info displayed steady. I was then able to change channels (of course screen was blank as antenna cable was unplugged) and enter the Viera menu. I immediately went to channel set-up and manually removed channel 26-3 from the channel list. After reconnecting cable, Viera was back to normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the Viera remote and front panel controls inoperable. Pure speculation, but it could be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel controls.
Posted on Jun 24, 2009
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: error codes. no picture or sound after turning
When the SUB5V or MAIN9V/SUB9V, short or over-voltage 15V short condition occurs, the TV shuts down and the power LED blinks 10 times.
Posted on May 16, 2010
SOURCE: Just bought a 50 panasonic viera, when we hook up
Plasma TV normally do not have the resolution required for PS3 unless the plasma TV is fullHD( 1920x1080p) pixels.
HD Ready Plasma = 1024 x 768p
PS3 Outputs = (fullHD)1920x1080 or (HDReady) 1280 x 720p.
LCD TV accepts the resolution matches the resolution the PS3 is outputting.
Posted on Sep 11, 2010
I have a 56inch panasonic Viera LED TV. it turns on and the sound works fine, and the screen lights up but it is a white blank screen with no picture. Suggestions?
Does it display channel numbers or other pictures when you press menu or other tools? If so, it's a problem with the TV's video inputs. If not, it's something wrong with the projection hardware, matrix, or power supply. Failing that, I recommend contacting Panasonic's support center, and keep any information you have on buying the TV handy. Good luck!
Dec 06, 2013 | Panasonic VIERA TH-65PV500 65 in. Plasma...
The picture at the bottom of my Panasonic Viera is cut off at the bottom. How can I fix it.
The picture is zooming in to much,u getting a close up large picture.Look in ur tv remote look for a button said like LCD MODE,VIEWMODE or P.SIZE,push one of those buttons on the remote to pick a picture differece view modes.That can fit ur tv screen.
Oct 14, 2010 | Panasonic Viera TC-L32C12 32 in. LCD TV
Have sound but no picture on plasma green light is
check out for high voltage regulators near picture board. need servicing resoldering the whle unit and heated area..try it
Oct 27, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
PANASONIC VIERA 50", BLACK LINE COMING UP FROM BOTTOM OF SCREEN
this problem sounds like bad solider on the vertical IC chip.
re solder pins and should run fine.
Jan 11, 2009 | Televison & Video
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
