Question about Toshiba Satellite A135-S4527 Notebook
Mouse freezing once you log in the lap top - Toshiba Satellite A135-S4527 Notebook
Image pad light comes on ocassionally, lap top freezes, can not turn off. HP Envy Windows 7
Good Day,
For clarifications, is it that the computer freezes or the mouse pad doesn't work again while the keyboard still works?
Because for your type of laptop, around the top left corner of your mouse pad, there is a small hollow. If you double tap this place, you deactivate the mouse pad and if you repeat the tapping, you activate it. That's why the light there comes on and off. So may be you check it to know if you tap here during your typing.
I hope this helps you? Thank you for using Fizya!
Jul 23, 2012 | Computers & Internet
My lap top mouse orange light is on and i can not use the mouse pad on lap top
look closly to the mouse pad usually around it may has a botton click on it
Sep 25, 2010 | Computers & Internet
My mouse works fine while logging into my desktop but once i get there my mouse freezes up ????
Do you have an external mouse plugged in, if not, you may want to uninstall the Snapytics Driver. (not perfect spelling) but this driver disables the internal mouse if it has a problem or if an external such as usb is detected.
Apr 14, 2010 | ASUS Eee PC 1000H Laptop
I can log in to my lap top but once i try to go on to the internet the whole system freezes and will not work although the internet connection is fine.( it will let me use skype spotify etc) If i try and...
ur laptop have partition for recovery, now u turn on ur laptop and keep the key f11 i will go to recovery systems and u recovery wlth format the partition after i think it all ok
Jan 13, 2010 | HP Pavilion dv9000z Notebook
My mouse on my compaq lap top is terrible The
hello,
Please reinstall the touch pad drivers once and if then also it is not working the needs to be replaced.
Thanks
Dec 10, 2009 | Compaq Presario Notebook
Lenovo N500 lap top - mouse is inactive. Need
Some laptops have a key sequence to activate or disable the onboard touchpad.
Look for Fn+F8(or another combination) the key should have a mouse symbol on it.
May 11, 2009 | Computers & Internet
How to install logitech mouse
first off when installing usb devices always start the installer from the cd first. then once the installer is done restart your computer, then plug in the usb antenna for the mouse on a available usb port on your computer. most of those mouses have to be charged as well before their initial use.
Nov 30, 2008 | Logitech Cordless Mouse
Advent 7110 shuts down. P.C. World have had it back several times. No improvement. Seems that fan is not in right place i.e. under lap top. Could it be an overheating problem in which case there should...
I bought my 5535 yesterday and had exactly the same problems with it. going to take it back today and buy something else, it's cutting off every 15 minutes. very irritating. i thought it was overheating on my lap so i used it on the table just to get the same results. This is not a common issue for acer and these should all be recalled
Nov 07, 2008 | Computers & Internet
Mouse on lap top dosent work
Can you tell me the model of laptop you have? Have you checked the settings in the control panel?
Nov 30, 2007 | KEIO PS2 Optical Scroll Mouse
Toshiba Satellite A135-S4527 Notebook Logo
14 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
