Question about GPS
Parrot problems When some one is talking to me it fades in and out.
How much baby food must a baby parrot eat my baby does not eat much
talk with a vet
maybe you are not using the correct food for baby parrots
Oct 26, 2016 | Cats
Parrott bluetooth manual
Thank you for posting your problem on fixya. Am pleased to help you. Since, the Parrott bluetooth product name or number has not been mentioned, i would request you to check the following site to download your manual. http://www.parrot.com/usa/support/onlinehelpfiles .
I would also request you to provide a brief detail of your issue next time for effective assistance.
Thanks and have a great day. Feedbacks are appreciated.
Nov 01, 2010 | Cell Phones
Parrot 3200 problems with push to talk on blackberry 8330
Did you have this trouble already ? or did it came recently?
Cause that could be different reasons to get this impossibility.
Check the profile of the phone to see if you have the handsfree profile, because in some mobiles, the profil headset is set up and then doesn't allow to use the buttons of the kit.
If the push to talk is to build the voice contact before using the push to talk which is not specifically correlate with the one from the phone.
Did you use into the kit (settings -> pair with phone a specific menu in the kit?
Unfortunately i do not have the info from the phone, but still the most common troubles are oftest due to the interaction of voice control and contacts from the phone to the kit.
Mar 24, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
CK 3200 LS severe background noise heard by other party - Can download software update ok and pair bluetooth laptops ok, but when I try to send download to Parrot on some computers I get message no dongle,...
get your laptop and car ready then call parrot techinical, they will talk you through it, you need to select the correct serial port. it also depends on what type of donlge you are using.
Nov 13, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot CK3100 lcd control isn't working.
try pushing the wire into the bottom of the display, this comes loose easily and causes these problems.
Oct 21, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
LG KP500 cookie
Had the same problem..If you copy the contact list (Which the parrot sees empty) to the phone memory as well as the sim card then set the phone to read only internal contacts it will upload the list for you and not double up the contacts.
Only trouble is the Cookie does have a habit of shutting down and restarting every time it hooks up to the parrot or when you end a call. The problem can be helped by uploading the latest parrot software but its not a 100% cure..
Dec 20, 2008 | Cell Phones
GPS Logo
66 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
