Question about Baby Gear
I have a bassinet by avalon products inc., model A95DL. I lost 2 bottom horizontal poles which have threaded holes in either end for a bolt to go through in order to attach to the vertical poles. do you know if you can get replacement parts? It was bought at Zellers in Kitchener, Ontario and made in May of 2010.
5 Suggested Answers
  • 3 Answers
SOURCE: replace parts
call 18005441108 -- they will provide you with any replacement part needed -- just have credit card ready!
Posted on May 27, 2008
SOURCE: Simplicity 4 in 1 bassinet
I need instructions to back together the 4 in 1 bassinet
Thanks,
Mary
Posted on Jan 10, 2009
  • 59 Answers
SOURCE: Compant no longer carries this specific model. The pilot holes were drilled by manufacter too close/crroked so when it was put togther it chipped the wood,. I now need replacement part. It is the long
You can fix this with wood glue - But if you want replacement parts you have to go back to the manufacture.
Posted on May 16, 2009
  • 4 Answers
SOURCE: Looking for a replacement part for a bassinet.
I am looking for a few parts for my bassinet! I need help
Posted on Jan 11, 2010
The bolt on the bottom of my alternator fell and is lost, i have to know the size of it to replace, anyone know the answer?
Use one of the other alternator bolts for testing, see if the threads are the same on the other bolt hole. If the bolt is a little long or short, just get a different length bolt from the hardware store.
If nothing else, use a tap and die set. If enough meat around the hole, drill the hole and retap the threads. Just a thought.
You didn't give year--make--model?
Jul 26, 2015 | Cars & Trucks
I need the written instructions to set up an avid screen gazebo 13x9 model 2086 that I just bought at a yard sale. PLEASE HELP.
How To Assemble Avid Outdoors Model 2086 Screen Gazebo
Start with # 4 poles. There are 4. Attach a #3A to each, and then attach #3 to the other end of the 3A.
These are the 4 legs.
There are 6 #2 and 3 #2A. Attach a #2 to 2A, and then #2 to the other end of the 2A. These 3 are the top ridge pole and the 2 side poles.
I believe there are 4 #1 and 4#1B. Attach a 1 and 1B together. Do this 3 more times. These are the gable poles.
You have 2 connectors that say gable and gable. These are for the top pole and 2 gable poles. You have 4 connectors that say gable and leg. Put the leg poles.....in the "leg" hole, the gable pole in the.....gable hole, and the side pole in the remaining hole. That shoule do it. It's easier to put the top together first, and then get 4 people to raise it onto the leg poles. Yes, the leg poles angle out, not straight down.
Jun 26, 2013 | Garden
Will not run unless choke is on
The jet in the Carb is gummed up. Take that 1/2" bolt off the bottom of the Bowl..That IS the Jet. Many times the Bowl will just hold in place with the Bolt out.. make sure the three holes are clear. 2 are close to the head of this bolt and you should have a real small hole where the threads end. Screw it back in...see what happens
Sep 21, 2012 | Garden
I lost instructions for my Avid Outdoors screen gazebo model #2086 13'x9'. Any help is appreciated
avid outdoor doesn't offer instructions...can someone please post instructions for some of these...it would really be helpful...its crazy that some of these boxes dont come with instructions?!
Jul 18, 2011 | Garden
Ive got a 10x10 lawn and party gazebo made by summer rite ... do you know where to get instructions ?
Okay, Here it goes.
First lay out all of the parts by number (little stickers on poles) or sizes if the stickers are gone.
_1430.jpgTake
Take the 1's and 2's and connect them together creating one big pole that will act as one of the roof peak structures. If you have lost your numbers, these two poles should be the two middle sized poles (4 of each).
Then connect each end of #1 to the center peak piece
Once all four combined poles (1 and 2) are attached to the center piece, add the pole brace pieces to each end of the bottom or #2 Piece.
Once this is done, combine two number 3's with one 4 (the 4 being in the middle of the two with both silver metal fasteners on the #3 poles facing outwards)
Then connect each end of the combined poles to the end piece.
Now lay out the final set of poles (# 5 and 6), but only connect the #5 pole to the end piece first, all around the gazebo.
Okay, now we want to start adding the actual canopy. Start by pulling the corners down at each pole joint then velcroing the tarp underneath in the middle of the 3-4-3 combined pole.
Now it is safe to connect the next set of poles (#6) to the leg poles (#5). Make sure the end with the 3 drilled holes are closest to the ground. On each end of the tarp legs there is a silver hook. Hook this into the 1st hole in the pole for support.
Connect the foot cap to the end of each pole and then connect the plastic o ring to the connector on the foot piece and readjust the silver hook as needed to either hole 2 or 3 (see photos).
Then the final parts are easy, secure any velcro straps to the legs, then use the stakes to stake down the whole thing and you may use the secure ropes as needed though I tend two just put two stakes in each foot piece at different angles.
Congratulations !!!!! Your Summer Rite Gazebo is ready for festivities. Hope this helps !!!
Sincerely Dustin R. Sponsler
May 30, 2011 | Camping, Backpacking & Hiking
Assembly?
This is a tricky little bassinet to connect to the head and foot board. You should have 2
bolts that are double ended (one threaded one is like a nut with female threads).
These go thru the holes on the headboard and I think the inside (bassinet side) have little guides
or bushings that the bolts ride on. The bottom parts use barrel nuts and long (4-5") bolts. Carefull not
to overtighten these as they will break the wood. There is a small rod that is underneath that locks the bassinet in place keeping it from rocking. Again, they just changed this design and my description may not be exact to yours. I cant seem to find an online source for instructions and Eddie Bauer just went thru
a bankruptcy so who knows. Good luck
Feb 21, 2011 | Eddie Bauer Newport Bassinet
I have lost all the bolts and hardware as well as the covers for the bassinet. Can I buy replacement parts?
If you have any of the parts you can match them at a local hardware store. If you have misplaced all the nuts/bolts or screws, try to find a compatible bolt that you can use to determine the thread size, once you have a sample of the thread size. use a "toothpick it determine the depth of where the bolt fits, the depth of the bolts will probably be the same for all. Take the bolt and thread depth to the hardware store (Ace, Home Depot, Lowes etc) I am sure you will find someone to help.
Feb 10, 2011 | Eddie Bauer Musical Rocking Bassinet...
Remington electric pole saw stalls in vertical positon
check the bottom of the chain guard, look for a loose bolt just inside the housing.
Nov 02, 2009 | Remington Polesaw Wizard
Battery hold down
well i have seen two types.
1 is just a rigid plastic bar placed across the battery (normally between the battery holes or the square cover of the holes) then they have holes on each end and two long bolt with a bend at the ends to hook up on holes at the bottom where you put the battery. these bolts comes out in the hole of the horizontal plastic and have threads so you can put washer and nut on it to secure the battery down to its place.
another thing that is saw is basically the same as the one described above except that instead of just a horizontal rigid plastic bar, this one is a rigid plastic also but it holds onto the whole battery. is is like a rectangular plastic that you place on top of the battery and ;again , they have holes on the sides to fasten it using the long bolts with bends on the ends and catches the hole on the metal where you place your battery.
whew.. i hope i was able to really let you visualized what i am talking about.
tnx 4 using fixya,
drcool
Sep 23, 2008 | 1998 Ford Taurus
Baby Gear Logo
148 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
