Question about Wahl Magic Clip Clippers Hair Trimmer
Wahl chrome pro clippers are very noisy tried to adjust them?
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
SOURCE: reassmbling wahl product
Q. How do I align my blades? faq1.jpg A. ALIGNING BLADES
  1. The bottom blade holes are larger than the shanks of the blade screws. When the blade screws are loosened the bottom blade can be aligned with the top blade. Tighten the screws after the blsde is aligned and ensure that they are kept tight.
  2. The end of the top blade teeth should be aligned 1/32" to 1/16"(.79mm to 1.59m") back from and parallel to the bottom blade. It is important to align your blade properly to ensure that the clipper does not cut too close and to prevent the moving cutter from touching the skin.
  3. faq2.jpgThe extreme left hand tooth of the top blade must be covering or be to the left of the first small tooth of the bottom blade.
  4. The extreme right hand tooth of the top blade must be touching the big tooth of the bottom blade.
Q. My clipper/trimmer is making a loud "clunking" sound, is it broken? A. No, the unit is not broken. Rather, it is not properly tuned and as such it is not operating at maximum power. To adjust power (tune), turn the power screw in a clockwise direction until you hear a noise. Then, slowly turn the power screw out (counter-clockwise) until the noise stops. This is maximum power.
Posted on Mar 17, 2009
  • 3 Answers
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Posted on Jun 20, 2009
  • 30 Answers
SOURCE: wahl magic clip clippers are very noisy , tried to adjust ?
1 or 2 basic things happened. 1st there is an armature adjustment on the right hand side when viewing the clipper from the top (it looks like a screw). Place a screw driver in this and turn it counter clockwise, if this screw is up against the stop than you can place a small screwdriver behind it and pop it out (this is actually a cap) now you can access the actual adjuster. back this out about an 1/8 of a turn at a time until the noise stops, turn them side to side to insure that the armature is far enough off of the motor coil. Then replace the cap.
Posted on Sep 21, 2009
wiringlunati
  • 576 Answers
SOURCE: my wahl clipper is very noisy, what should i do to
First, they need to have a drop of oil put on the cutters every time they are used. Second, there is usually an adjustment screw on the side of them to adjust the travel of the moving cutter. Adjust that so that it completely goes across the slots in the stationary one, but not too far or too noisy.
Posted on Nov 25, 2009
Why won't blades stay aligned?
Ok either the 2 screws that hold the blade to the clipper are loose or the adjusting lever on the side could be loose please check both.
P.S you must align blade before you tighten the screws.
www.angliaclipperservices.com
Anglia Clipper Services professional dog grooming equipment
Aug 25, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
Wahl clippers
Have you read the instructions and put it together the right way?
Sep 29, 2013 | Wahl Home Grooming Animal Clipper Kit With...
Wahl KM-SS pet shaver motor runs but cutters dont move
it seem that shunt arm that move the cutter blade is broken or off it's guide without look at it it's hard to tell what wrong, try Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers. they can help.
Mar 05, 2010 | Wahl 8892-002 Kennel Pro Clipper Kit
My wahl clipper is very noisy, what should i do to fix the problem
Nov 24, 2009 | Wahl Magic Clip Clippers Hair Trimmer
I have a brand new pair of wahl clippers and they dont cut. they just buzz. is there something i have to do?
check on the side for a screw to adjust the blades. It's meant to be use with a straight screw driver, you need to go left or right until it sounds perfect, otherwise it will sound weird so until it per's like a kitten keep moving that screw.
Oct 21, 2009 | Wahl 8892-002 Kennel Pro Clipper Kit
Wahl magic clip clippers are very noisy , tried to adjust ?
Jun 28, 2009 | Wahl Magic Clip Clippers Hair Trimmer
Health & Beauty Logo
67 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Ngoro
Ngoro
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
