Question about Vehicle Parts & Accessories
Car does not recognize gear shifts
I have a 2006 BMW X5. When I put the car into any gear the gears are not recognized on the cluster/dashboard and the car would not move. After several attempts the car would not start.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 81 Answers
WHen moving the gear selector, could you feel the vehicle engaging the gears?
The vehicle may not start as it thinks the selector is in gear not in park.
It sounds like a selector switch issue.
WIth accessories switched on, place car in reverse (without enging going) and see if reverse lights are on.
Posted on Jan 05, 2014
  • tace899
    tace899 Jul 26, 2014
    Does the shifter feel very loose? you may have a loose / broken gear linkage (unlikely, but possible).
2 Suggested Answers
  • 10 Answers
SOURCE: I have problem with my Mercedes E350 Automatic 2005 model. It doesn't change gears when the car is cold so it feel like driving in first gear no matter how much I accelerate. When the car heats up I n
When was the last time you had the tranny fluid and filer changed? I hear that they recommend changing it at 60,000. This model has extensive electronic sensors and interface controls on the engine and trans axle (nothing is simple anymore... :( ). Just from what you described, i would think that perhaps there is a relay or sensor connected to the trans axle that is not functioning properly ( especially when cold ). Since you have to restart the engine when warm to get it to work, it makes me think a relay is being re-set when you re-start the car. The car should shift properly whether cold or warm. I hear that you will have problems shifting if the regular 60,000 mile changes are not performed on the trans-axle fluid. If it were me, I would try that if you have not already done so in the last 60,000 miles.
Posted on Apr 11, 2013
Gear changes not recognized on 2006 BMW x5
The obc has recognised (it thinks) a security issue and needs BMW to recover and reprogramme the obc.
Jan 03, 2014 | Vehicle Parts & Accessories
Either the actuater is faulty or the gear box.some times the filter inside the gearbox needs to be replaced.Have a proffessional look at it.
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
My 2005 X5 4.40I this briefly displayed something like "Hillshare Program" on the dashboard this morning, next thing I know the car started drivinig slow and will not go to a higher gear. Running on h
You've a faulty EGR(Exhaust Gas Recirculation)valve problem. It has to do with emission control and you will not get enough power to achieve speed for trans shift higher when the EGR is bad. Replace the EGR and all will be well.
Jan 31, 2013 | 2005 BMW X5 4.4i
Transmission failsafe program
You have bad shift valve more than likely the lockup valve is sticking or the govenor is not working correctly.
Jan 29, 2013 | BMW X Series & X5 1997 >2006
My 2002 BMW x5 seems to be idling for no reason and the truck starts jerking when in drive position.
Ur BMW X5 series is having a transmission problems and it going to be worst if u don't take this car to a AMGO or the BMW dealership to take a look at it transnission gear box.Must have the car transmission fix.If u adnore this problems long enough the car transmission gears in the box will evenly buckle and grain to a ruin all of the gears parts teeths and than the car have to be in reverse and go to drive again every times tries to drive this car.Evenually all the gears teeths in the transmission box are all gone this car will go into iddle and will not go into drive gear at all.
Sep 18, 2012 | BMW X5 Series Cars & Trucks
Bmw x5 slow gear change
this is normal to some extent to try and warm up the tranny to opp temperature as soon as possible. make sure the vehicle had the latest software installed in the transmission as this could also cause a delayed shift when cold.
Jan 22, 2009 | 2004 BMW Z4
Vehicle Parts & Accessories Logo
96 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
