Question about Curtis 24" Class 1080P Led Hdtv/Dvd Player
Where do I plug in a passive indoor antenna to AVOL TV?
I'm trying to hok up a passive indoor antenna to an AVOL flat screen tv but I'm not sure where to connect it.
3 Suggested Answers
  • 100 Answers
SOURCE: I just bought an LCD
Few things,
  1. You will have to go into your menu settings and be sure to select "Air" instead of Cable for your antenna connection
  2. Then run auto scan channel setup to find all available channels in your area
  3. Once completed be sure you are on Input Source TV you should be able to select Channel up/down on the remote to select your channel to view
If you ever see No Signal you are probably on an AV input and not on your antenna input.
The full PDF manual can be found here:
http://www.curtisint.com/html/custservice/manuals/CUR_LCD1933A_EN.PDF
I hope this helps
Magoo
Posted on Mar 11, 2011
vinceisaac
  • 2432 Answers
SOURCE: Antenna shuts tv off when plugged in
their might be a problem with the tv tuner, what kind of antenna have you been hooked up an areal antenna?.
Posted on Sep 04, 2012
I have a 2004 Samsung cable ready tv. Bought RCA passive indoor antenna. do not get any channels except 6 Guadalupe Radio TV
Get a different antenna or install a roof antenna from radio shack.
www.aaatvservice.com
Aug 16, 2014 | Televison & Video
My Tv says Not Programmed
Your indoor antenna will plug into the same RF Antenna input jack as would an outdoor antenna. It will take some time but let the unit go through its entire auto tuning mode. If stations are available in your area and signals strong auto tuning will pick them up.
Mar 05, 2014 | LG Televison & Video
My rca indoor antenna will not pick any channels up on my hd flat screen tv
Signal not strong enough in your area for this indoor ant...Does it work with an outdoor ant?
Nov 29, 2013 | Televison & Video
Indoor antenna won't work on my cable ready set
You do have to make sure to switch the settings to an external antenna. You also will have to check that you have what is an analog signal available to you. If you antenna is analog it will only get analog broadcast. You may also need to switch to a digital tv antenna, The other thing is the range of you antenna. Most indoors, in a congested area will only pull in signal from about 20 to 25 miles out.
Jun 18, 2013 | RCA Ant121 Indoor Passive Antenna
How to get rca indoor antenna to pick up free digital channels on my Samsung television
Indoor antennas are not very good if you live far away from the TV transmitter. Antenna aim has to be more precise than before with analog TV's. If you can put up an outside antenna you'll probably get them all.
Mar 18, 2013 | RCA Ant121 Indoor Passive Antenna
Advent tv indoor antenna hook up
If the antenna has a cable like cable wire--hook it direct to the cable fitting on the set.
If the antenna uses the flat type wire (called 300 ohm twin wire) use an adapter that will connect to the end and have screws for the flat wires and a cable slide on the other side to slide onto the cable fitting on the rear of the TV
Mar 28, 2012 | Recoton Advent Advent DV1418A 14 in....
Hook up to digital TV antenna indoor passive
Please check if the antennae is connected with right cable and the dipole is good. If so search the channels avaiilable and if there is no signal then it is possible that the TUNER is faulty. check using another TV with the same antennae or check the RF input using a VCR or TUNER.
Oct 30, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
I bought HDTV/UHF/VHF/FM INDOOR PASSIVE ANTENNA please help me to install it it is not working
Is the antenna the correct one for your environment? Do you have the antenna pointed at the stations you want to receive? Use antennaweb.org or tvfool.com to get an idea of the location and likely channels you can receive at your location. Antennaweb assumes an outdoor antenna but is very conservative in the list of channels you can receive. (These may match the limits of the indoor antenna.) TVfool lists the stations and the appropriate antenna that will likely receive each station.
Tall trees and buildings will block the signal. Get the antenna as high as possible. Move the rabbit ears and UHF loop to maximize your signal strength. Then make sure the TV is set to use the OTA tuner (ATSC for digtal stations). (That may mean changing the source in the setup menu.)
Then scan for channels. Move your antenna or parts of it and rescan or edit the channel list. (For some TVs there is a weak signal setup option that will let you manually enter the station number (including sub-channel). Then it will provide the signal strength information as you move your antenna.)
I hope this helps. An amplifier may help you bring in weak stations with enough signal strength for the tv to see them.
Jan 19, 2011 | Philips Televison & Video
I bought a Proscan 26LB30Q TV. After connecting to the indoor digital antenna, no signal showed up on the screen. What could be wrong? Thanks.
MAKE SURE WHERE YOU HOOKED UP THE ANTENNA SAYS DIGITAL,,IF ITS NOT IT WANT WORK ON TOUR TV,, POEPLE THINK JUST CAUSE ITS A NEW FLAT SCREEN THAT IT DIGITAL,,, BUT A LOT OF THEM STILL ARE JUST ANALOG ANTENNA READY,,,,,THE ANTENNA JACK SHUOLD SAY EITHER ANALOG OR DIGITAL,,
May 15, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Curtis 24" Class 1080P Led Hdtv/Dvd Player Logo
374 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
