Question about Royal Sovereign Heating & Cooling
Need replacement remote for portable air condition unit ARP1008K 8000BTU serial #08020637 cannot reach anyone by phone and no one has call me back. Need to know if temp can be adjusted without remote
    Sergeant:
  • 296 Answers
Please check the link bellow to choose your area and then you can call the appropriate help line.
http://www.thomasnet.com/branches.html?cov=NA&what=Air+Conditioners%3A+Portable&heading=700864&cid=30148680
Thank You
Posted on May 21, 2009
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    www.youtube.com/watch?v=kx1_1q4ByC8
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
I lost my user manual for my 4 in 1 portable air conditioning unit. Does anyone know where I can find a replacement?
Hi, you don'tmention what model you have but don't worry; most portable 4 in 1 airconditioning units are similar. Here is a link to a user guide that should helpyou. http://www.onninen.com/sweden/produkter/onnline/Documents/Manual+OPAL+AC%201.pdf
Jul 17, 2012 | Soleus 4 in 1 Portable Air Conditioner
Just given an older model delonghi portable air, when u open the front there is a container like thing, I don't have any instructions do I fill it up with water? or does that collect the compensation...
No need to fill that with water, it will collect the condensation on it's on. You will be required to drain it periodically, but the unit should let you know when that's needed.
If you can come up with a Model Number of it, I may be able to find an Owner's Manual.
Hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
I just purchased a used wintair room portable a/c unit, works good its 8000btu, it cools great, but i dont know how to work the buttons, and it has started leaking on my daughters carpet, do i need to...
There should be a plug on the rear of the unit near the bottom of the back. If the plug is missing/removed, it should have a barbed or threaded end for a drain hose to be installed. Place the drain hose (a typical garden hose will suffice) over the end of the barbed/threaded section and secure with a an automotive hose clamp. Some units did come with a "male" hose end in which the "female" end (what you would screw onto a outdoor faucet) garden hose can be directly threaded onto the drain connection. In either case, this drain needs to be leak proof to prevent additional water (condensate) from leaking onto the floor. The drain is ideal for situations where there is high humidity in which the A/C condenses the water vapor out of the air during A/C operation.
Feb 06, 2018 | Danby Portable Air Conditioner
MY 2YEAR OLD WINDOW AIR CONDITIONER WON'T POWER ON
Apparently the gfci on the plug (the reset button) has gone bad. The best thing to do is to purchase a new cord and replace it. These switches sometimes go bad. Good Luck
Dave
Jul 28, 2009 | Frigidaire FAC107P1A Wall/Window Air...
DPAC 13009 portable air conditioning problem
Remove your remote control on the unit, follow the manual step by step. First, do the emergency on/off button, then operate the air conditioning using the remote control, follow the procedure of your manual.You may notice a clicking sound of your remote control. The yellow/green color of your emegency on/off button will turn to blue. Do not put it back your remote control on the unit because he may sense the temperature of the vent, and your air conditioning will not stay on, it will shut off every five minutes. Your problem is solve.
Regards,
Cesar
May 24, 2009 | Danby DPAC12031 Air Conditioner
Size
Are you asking for Dimensions of the unit Quasar HQ2081QH 8000BTU Width 18.5 in. Depth 20.69 in. Height 13.88 in. Quasar HQ2101SH 10000btu Width 22.06 in. Depth 23.84 in. Height 14.78 in. Quasar HQ2121 12000BTU Width 22.06 in. Depth 23.84 in. Height 14.78 in. and the 5200BTU Quasar HQ2052UH Width 18.56 in. Depth 14.5 in. Height 12.28 in.
Aug 23, 2007 | Quasar HQ2052UH Air Conditioner
Heating & Cooling Logo
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
