Onkyo Tx sr313 usb no storage displayed and some functions on remote dont work Ie set up a and b speakers select listening modes All other remote functions work Help
2 Suggested Answers
tech48
  • 624 Answers
SOURCE: listening modes not working??
I am a little hesitant to tell you what this is because sometimes people give bad ratings to an expert when they do not get the answer they want to hear. I will take a chance here and assume you are a reasonable person and tell you what the most likely cause is. I have been reparing these type of receivers for as long as they have been making them, and every time I see this particular problem it is always something on the digital board. This is the board the the optical and coax inputs go into on the back. They also run all the audio thru this board, and when you only get the audio that you have, a problem is going to be found there. There is some good news and some bad news that goes with this, first the good news. Many times (about half), the digital board only needs to have some of the solder reflowed on a few of the IC's and it will return to normal operation. If this is the problem your repair should only cost from $90 to $150 depending on the rates of the shop. Now the bad news, if the board has a couple of bad compnents on it, it will need to be replaced. The reason that is bad news, is because those boards are very expensive, usually over $250 just for the board, if the board is even available. Many of these receivers you can not get the digital board for them. Most all of audio equipment is component level repair and there are not many technicians who can troubleshoot these boards, they are a very difficult task.
I hope this free information was helpful, and if so a "FixYa!" would be the appropriate rating. You do not need to have your receiver fixed in order to give a good rating, only that you are given the correct information.
Let me know if I can be of any more help to you, good luck with your Onkyo.
Dave
Posted on Nov 10, 2008
I have an TX-SR313 for a year now and it was working perfectly until yesterday it just automatically shots off even when I turn it on for several time it just shots off. How can I solve that Problem?
Hello, It seems like the receiver is going into protection mode. A unit will only go into protection mode for two reasons mainly. The first reason is if there is an internal short. The second is if there is an external short which is typically only caused by one or more of the speaker connections. To isolate whether the short is internal or external, you would first need to unplug the receiver and disconnect all of the speakers. At this point you will plug the receiver back in with no speakers connected and turn the unit back on. Also turn the volume up to about 70 (even with no speakers connected). If the unit stays on that means that one or more of the speaker connections was causing the receiver to go into protection mode. If the receiver shuts off again with no speakers connected, then that means the unit would have an internal short and would have to go in for service. Thanks, FJD
Apr 17, 2016 | Onkyo Tx-sr313 5.1-channel Home Theater...
Fix onkyo ts-sr313 turn on problem
If the relay clicks on and then off straight away then it might have detected an overload condition and so shuts down. Overloads can be caused by faulty speakers or wiring. But if the damage is done already then one of the main power amp transistors or other devices could be short circuited.
Oct 16, 2014 | Onkyo TX-SR313 Home Theater Receiver - 5.1...
SERVICE MANUAL onkyo-tx-sr313
i need a manual service for onkyo tx-sr313
May 01, 2014 | Onkyo Tx-sr313 Txsr313
Onkyo TX-SR309 - Sound output only from 2 speakers from five. Hi, I have a Onlyo TX-SR309 receiver connected to a Wharefedale MS100HCP speaker package. It was working fine for 15 months but now the...
Some info from the manual:
The Dolby Digital and DTS listening modes can only be selected if your Blu-ray Disc/DVD player is connected to
the AV receiver with a digital audio connection (coaxial,
optical, or HDMI).
• The listening modes you can select depends on the format of the input signal. To check the format, see "Displaying Source Information"
• While a pair of headphones is connected, you can select the following listening modes: Mono, Direct, and Stereo.
• While Speakers A and B are on, you can select only the
Direct, Stereo, Mono, or T-D (Theater-Dimensional) listening mode.
Plus this Bit of info on the speakers A and B buttons.
While Speakers B is on, channels are reduced to 2.1 in the
main room.
If you can access the speaker configuration it should provide test tones to each speaker. If you can't the speaker A and B are not set right.
If you have pressed the stereo or mono button no sound will be heard except from the front two or the sub.
Sep 01, 2017 | Onkyo Audio Players & Recorders
I am trying to connect my Onkyo DS-A3 ipod dock to my Onkyo TX-SR508 receiver and I cannot get the TV to display the ipod menu. I've connected the red and white (R/L) and yellow video cable to the...
Is OSD set to ON? See below
Set the OSD (onscreen display) mode before you start using the RI Dock. 1. Plug in the AC adapter. 2. Turn on your TV and amp, and select the appropriate inputs on your TV and amp. 3. Insert your iPod into the RI Dock. 4. Select the video output mode depending on the video connection. While pressing the remote controller's [SETUP] button, press the Up [ ] button for the component video connection, press the [ ] button for the composite (default) connection. 5. Use the remote controller's [MODE] button to set the OSD mode. On: Playlists (artists, albums, songs, and so on) are displayed on your TV, and you can navigate and select your music or video while looking at your TV. While this mode is selected, your iPod displays the Onkyo logo. Off: Nothing is displayed on your TV and you navigate and select your contents by using your iPod's display.
Mar 15, 2017 | Onkyo Audio Players & Recorders
Upon powering up my Onkyo TX-SR605 receiver, it enters Audyssey setup mode even though the microphone is not plugged in. Even if I plug in microphone and remove it, it still stays in Audyssey mode and I...
I have the same problem and it is not speaker wires, cables, or dumb remote codes (really, remote codes.) I'm taking mine in for repair, and not reliying on straw grasping, speculative solutions.
Jan 25, 2011 | Onkyo TX-SR605 Receiver
Onkyo Tx SR606 Listening Modes "Not Available" Via Optical I have my Sky+ Box plugged directly into my TV with an optical cable from Sky box to my 606. I had no problems changing the listening modes untill...
check to see if the DIRECT icon is illuminated on the panel...if so, cancel the DIRECT function. This is only a thought, also check HDMI settings as well as optical mappings...
Jun 01, 2009 | Onkyo TX-SR606 Receiver
My Onkyo TX SV 535 Surround Sound wont work
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
104 people viewed this question
 Grubhead
Grubhead
