Question about Vehicle Parts & Accessories
I have a 2006 BMW X5. When I put the car into any gear the gears are not recognized on the cluster/dashboard and the car would not move. After several attempts the car would not start.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Either the actuater is faulty or the gear box.some times the filter inside the gearbox needs to be replaced.Have a proffessional look at it.
Posted on Jan 05, 2014
Gear changes not recognized on 2006 BMW x5
The obc has recognised (it thinks) a security issue and needs BMW to recover and reprogramme the obc.
Jan 03, 2014 | Vehicle Parts & Accessories
Car does not recognize gear shifts
WHen moving the gear selector, could you feel the vehicle engaging the gears?
The vehicle may not start as it thinks the selector is in gear not in park.
It sounds like a selector switch issue.
WIth accessories switched on, place car in reverse (without enging going) and see if reverse lights are on.
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
My 2005 X5 4.40I this briefly displayed something like "Hillshare Program" on the dashboard this morning, next thing I know the car started drivinig slow and will not go to a higher gear. Running on h
You've a faulty EGR(Exhaust Gas Recirculation)valve problem. It has to do with emission control and you will not get enough power to achieve speed for trans shift higher when the EGR is bad. Replace the EGR and all will be well.
Jan 31, 2013 | 2005 BMW X5 4.4i
My 2002 BMW x5 seems to be idling for no reason and the truck starts jerking when in drive position.
Ur BMW X5 series is having a transmission problems and it going to be worst if u don't take this car to a AMGO or the BMW dealership to take a look at it transnission gear box.Must have the car transmission fix.If u adnore this problems long enough the car transmission gears in the box will evenly buckle and grain to a ruin all of the gears parts teeths and than the car have to be in reverse and go to drive again every times tries to drive this car.Evenually all the gears teeths in the transmission box are all gone this car will go into iddle and will not go into drive gear at all.
Sep 18, 2012 | BMW X5 Series Cars & Trucks
I have an issue with my bmw x5 e53 regarding pixel loss on the radio and instrument cluster. Its begining to be a safety issue because I need to read data of the screen but makes it impossible sometimes...
there is a plsce in USA that will repair the radio or istrument cluster for under $200. Yuo can find them on ebey just put in X5 instrument cluster repair and they should pop up. I had my radio dislay repaired and they did a great job.
Aug 24, 2010 | 2005 BMW X5
I have fault code EGS (054) 36 Gear monitoring 4, BMW X5 E53 3,0 D 2002
2003 X5 bmw the trans. fail safe program comes on when driving, I was told that the trans needs to clean out and put new sensors. Is that true it gives the code 055
Apr 09, 2010 | 2004 BMW 5 Series
Transmission problem bmw x5 automatic
dear friend-the fact that your vehcl does not pick up speed tells me that it is slipping,there is a pressure lost in the gear box,you have to remove and rebuild as the clutches will be burnt.
Apr 07, 2009 | 2002 BMW 5 Series
Vehicle Parts & Accessories Logo
77 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
