Question about HP LaserJet 4700 Printer
The printer autostops
Hi im trying to print a document from indesign and when the it trys to conect to the printer the process stops and in the status says stopped. After a few minutes of trying to print.
I have tried from other computers and it doesn't work either. But if i print from word it works.
  • sofiagoya May 21, 2009
    is ip address. I've try to print from an other printer the same file, and it didn't work. Could be something related to the RAM?
  • Alex Howard
    Alex Howard May 11, 2010
    How do you have this printer instaled? USB, Parallel, or IP addressing? And are you printing to the printer the same way from all applications?
  • 484 Answers
This does sound like a memory related problem, or memory and configuration together. I am not at all familiar with the software you say you're using, but if you get the same problem from two different printers, using the same software, then generally you have just narrowed the problem down to the software, since the two different printers respond the same way.
Have you tried to contact the tech support people for that software package? If so, what is their recommendation?
I am sorry I cannot offer more than this, to help you solve the problem.
-a.
Posted on May 22, 2009
Lexmark z31 printer will not stop printing
Disconnect printer cable from PC. Power off printer and unplug power cord from outlet. Wait 15 seconds. Press the power button as if to turn on with unit still unplugged. Plug back into outlet and turn on printer.
Before reconnecting to PC, check the printer's queue status. Start, Control Panel, Printers. Select the printer by double clicking to open queue status. Select any remaining documents and choose cancel from document menu bar.
Bret
1-2-1ComputerServices
Oct 04, 2009 | Lexmark Z31 InkJet Printer
My parents have a HP P1505 and they are having trouble printing from InDesign documents. They get intermittent and funny type issues when printing straight from the document. Prints fine from a PDF. Prints...
Go to indesign. Under print options, go to output and select Greyscale instead of RGB. This takes acre of outputs from Indesign. I think the problem arises from the printer trying to interpret the colors.....
May 07, 2009 | Office Equipment & Supplies
Printer stopped printing color images
hi im josh in cebu phils .friend may i help you? The problem appears on your print out is a symptoms of software corruption. Try to re install new software driver for printer. but dont forger to uninstall the old one before installing a new. check also the printer port connection. good luck hope i helped you.
Mar 14, 2009 | HP Photosmart C7280 Laser Printer
Image enlarging when plating!
hi pip,
check your mac properties, if it is a PC powerchip, you may have to enable "Rosetta" in the indesign applications properties folder.
this may resolve the file print size conversion process.
Rosetta is inbuilt in mac with this type of powerchip, and when activated, works in the background..
http://www.apple.com/rosetta/ this link will give u an insight
not sure this is your answer....cheers rooboy
Dec 08, 2008 | Xante PLATEMAKER 4 Laser Printer
Won't print InDesign documents or Adobe PDF files
hi,
try to download a new postscript driver and install it instead of using pcl driver!
Oct 30, 2008 | Brother HL-5240 Laser Printer
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
Won't print when text on the page
Export the page as a jpeg, 150 dpi, high quality, then delete all the items on that page in the indesign document (text & images), then import the jpeg to that page it will fit exactly.
This works most times!
May 06, 2008 | Konica Minolta magicolor 7450 Laser...
Printing a tiled document from InDesign
you have check the tile option in print dialog box and select auto justified. now the printer will print tiled documents.
Apr 12, 2008 | HP Photosmart C3180 All-In-One InkJet...
Canon PIXMA MP160 Printer
This probbly some problem with the connectivity check your cables and try reinstalling the printer driver, check whether your printer is detected by your computer.
Good luck
Feb 18, 2008 | Office Equipment & Supplies
Duplex printing problem
you will need to make sure that the printer software is set to align top-top or top-bottom. You will need to set this within the printer dialog set up.
Jun 14, 2007 | Adobe InDesign CS2 for Mac
HP LaserJet 4700 Printer Logo
Seeker5211
Seeker5211
