Frigidaire crown series wont retain water - Washing Machines
2 Suggested Answers
chrisb_57
SOURCE: My frigidaire crown series washer won't drain the water
water pump knackered or check brushes or if moved washer drain hose kinked
Posted on Feb 29, 2012
Frigidaire dryer crown series model #FDEB23SRGS1 will not start
Check the breakers first . Reset both poles even though they may not show tripped. The wiring t the receptacle or plug could be loose. Los check behind it behind the back panel.
Feb 03, 2013 | Frigidaire Dryers
Feb 29, 2012 | Washing Machines
My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Feb 29, 2012 | Frigidaire Washing Machines
I have a Frigidaire dishwasher that is not workin...
Remove the drain end. Keep it above little . Check whether the water is retained inside the washing machine. If water is retained- check your drain valve in the machine. it is parmenantly open or having improper closure.
May 21, 2010 | Frigidaire 24 in. FDB510LC Free-standing...
Can anyone even tell us if a manual still exists for this model of frigdaire refrigerator the series is Crown and the model number F44922jt it is leaking water and we dont have a manual for it at all
I can find models close to that model. It is an older brand of Frigidaire and most of the model numbers may be just confusing. If your model has auto defrost then it must have a drain to drain the water from freezer to the bottom where there is a pan the water goes in and a fan blows warm air over to return the condensate to the air. If the drain inside the freezer is blocked that is your problem. I did try to find the user manual at Frigidaire and it was not listed but I can find models with similar numbers. Frigidaire mentioned also that if you wrote them they may be able to help. Here is a model I did find close to yours through one of the sponsors here. F44Q22JTD0 Let me get you some links and Be Righ Back, Sea Breeze
Jan 14, 2010 | Refrigerators
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
