Question about Case Logic Cl-bth-20 Bluetooth Headset
Have a cl-bt002 that i can't pair with my samsung
Code for CL
On many washers, CL is child lock. This feature locks the most of the front panel buttons; it's useful when you clean the control panel. It also keeps small children from starting the washer with a pet (or sibling) in the unit.
Look on the control panel for a small lock icon or the words Child Lock. This will be in a much smaller font than most of the icons/text on the washer. You need to press and hold the appropriate button or pair of buttons to disable the lock. If a pair of buttons are used, the lock icon will be in the middle of a line between the buttons.
Please add a comment with the specific make/model of your washer if you would like more information about cancelling the lock. On my washer, the CL will remain on even if you unplug the washer for several minutes.
Jun 12, 2017 | Washing Machines
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
Jan 19, 2016 | Washing Machines
Instructions to control samsung t v
Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Dec 08, 2015 | Samsung Televison & Video
How do you operate bluetooth CL-BT001-BK
Scanned manual available but is too large to load here. Basically, all functions are handled by the phone, the headset's only control is the on and off switch.
Nov 26, 2013 | Case Logic Radio Communications
I need instructions on BT002 battery tester
sure thing, you can find one here
http://www.gys.fr/pdf/manual/uk/055155.pdf
lmk if you need some additional help
Jun 25, 2013 | Measuring Tools & Sensors
Bluetooth cannot pair with other phones samsung S3653
Hi, it may happen if you have more paired list in the Cellphone. Please delete which you have already paired devices. Then try pairing new device. If it is not pairing then check whether you have selected Visibility in the Bluetooth settings.
Mar 30, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I cannot pair my samsung wep460 with my nokia 6303
You cannot pair samsung bluetooth device with other mobile brands. for pairing and mobile with bluetooth device you need an universal bluetooth.
regards,
mukesh
Feb 21, 2011 | Samsung WEP460 Bluetooth Headset
Samsung E570
What You Must Do Delete All Paired Connection on yr phone and try to pair again!!!!!!!!!! from KG
Nov 22, 2007 | Samsung SGH-E570 Cellular Phone
Case Logic Cl-bth-20 Bluetooth Headset Logo
37 people viewed this question
Top Case Logic Computers & Internet Experts
Lawrence Oravetz
rdjagger
Are you a Case Logic Computer and Internet Expert? Answer questions, earn points and help others
