Question about Samsung WEP500 Wireless Headset
I can't pair my case logic bluetooth to my phone
How do i connect my Bluetooth to a sound logic Bluetooth 2.1 speaker I bought it from a friend with no manual
Turn on speaker and then on phone or device check bluetooth pairing and see if you see the speaker.
Feb 05, 2015 | Audio Players & Recorders
How do you operate bluetooth CL-BT001-BK
Scanned manual available but is too large to load here. Basically, all functions are handled by the phone, the headset's only control is the on and off switch.
Nov 26, 2013 | Case Logic Radio Communications
Ikbt-50 driver needed
You don't need a driver! This is a Bluetooth keyboard. What you need to do, is pair it with your Bluetooth device.
First, charge the keyboard. Enable Bluetooth on your device. Now, push the small black button marked "ID" on the back of the keyboard. The button needs to go in pretty far. This will generate the Bluetooth code needed to pair your Device. You need to enter the four digit numerical code generated by the keyboard. That's it! You are paired!
Oct 25, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
Need pairing instructions for the case logic ikbt 50 keyboard for an ipad
You probably have the same problem I had. First, charge the keyboard. Enable Bluetooth on your device. Now, push the small black button marked "ID" on the back of the keyboard. The button needs to go in pretty far. This will generate the Bluetooth code needed to pair your Device. You need to enter the four digit numerical code generated by the keyboard. That's it! You are paired!
Aug 09, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
Case logic IKBT-50 user manual
Oct 29, 2011 | Cell Phones
1. What is the easiest way to pair a SGH-T456 phone with BLU Logic 1211 - which is in our Toyota Matrix 2. What is the easiest way to pair a SGH-T456 phone with our Toyota Camry 2010
Both questions -
Press the bluetooth link button in your toyota(s) and it should pop up a confirmation on your phone. Be sure your bluetooth is turned ON in the phone's settings, and that it is discoverable.
May 04, 2011 | GPS
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
Samsung WEP500 Wireless Headset Logo
24 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
