Question about Bissell 52889 Flip-Ease All-in-One Vacuum and Mop Vacuum
Stopped charging Is there a rechargeable battrie I should change
My vacuum runs down quickly. What is the best way to charge it up. I plug it in after using it every time ?
Hello, Janrt -
Depending upon how old the vacuum cleaner is, the rechargeable battery may need to be replaced so that the battery will hold a charge longer than it does now.
Rechargeable batteries do not last forever.
You will need to find the right replacement rechargeable battery for your vacuum cleaner. The web site for the maker of your vacuum may offer the right replacement batteries for sale.
Note: I have found that some replacement rechargeable batteries for some items cost more than the price of purchasing a replacement appliance.
Best wishes.
Jan 20, 2018 | Vacuums
The stick vacuum seems to be charging by the red indicator light turning green, yet will not turn on.
A rechargeable battery will only accept a charge only so many times - it is possible that you've reach that number. Anywhere between couple and a few hundred is about the maximum. Changing the battery will usually solve the problem. Good luck!
Oct 05, 2015 | Vacuums
Brand new first charge The green light on the charger plug goes off after a short time. Is the unit still charging?
Once the green light goes off, it's done charging. Since it was first charge I know they say to charge it 8? hours (or 4? don't recall right offhand) but it does come charged (that's part of how they make the batteries). What you do want to do is remember not to always recharge it when your done using it. Use it till the battery goes flat, then recharge it; it will give you a longer battery life that way.
Jan 09, 2015 | Dyson DC34 Bagless Cordless Hand Vac -...
I have a Dyson DC35. It has just stopped working. The green light on the charger is on and the vacuum is plugged into the charger, but it is like the vacuum is completely dead.
I had a similar problem. I have it on the wall mount and it turns out the plug that goes into the dyson to charge the battery had become unseated from the mount. I pushed it back in ("click") and that fixed it.
Mar 18, 2012 | Dyson Vacuums
I need the instructions for Black and Decker Start It How do I recharge it?
This unit is recharged using any household 120v outlet. Remove the rubber cap from the recharge port on the top of the unit. Plug the barrel end of the adapter cord into this port and then the put the adapter into the wall outlet. Make sure the power switch is in the off position. To check the charge level push the button to the left of the 3 indicator lights. When the green LED lights up, the unit is fully charged, (yellow is moderate charge and red is minimum charge).
Try to charge the unit from the minimum (red) charge level to maintain the maximum battery life and use of the product.
If you have misplaced the manual I am providing a link to it from Black and Decker's site.
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90550872,VEC010BD.pdf
Have a great day.
Jim
Dec 30, 2010 | Vacuums
When to recharge batter
hi right to be honest both ways are correct, but if your using it every day then its best to put it back on the charger after every use, but the problem with this is that the battery never goes totally flat, so never does a full recharge this reduces the life of the battery by upto 50% so if you are using it regular and need it charged daily then its best to once a month let the battery go totally flat so that it wont even make a sound then do a full recharge.
Doing this will ensure the battery remains at peak performance and make it last longer.
If how ever your only using it say once a week then its best to only charge after the battery has gone flat due to the fact that it would remain on charge longer and cause the battery to over heat reducing the life span of the battery.
But witch ever method you use always let the battery go totally flat once a month then do full recharge this will prolong the life of the battery and ensure it keeps working at full power.
Let me know if you have further questions ok
Jan 18, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
Model4210battry won't recharge, is it worth ordering a battery?
don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Scooba not working after full recharge
NiCD and LiOn batteries have this tendency. They work great for a year, then slowly die off. The problem is you. When new, the device MUST be charged for 14hr nonstop, then every 2-3 months run dead, and recharged again 14hrs nonstop. This is done so the CPU of the Roomba (cool toy) KNOWS what DEAD is and what FULL is. It does this by measuring the amount of currrent flowing thru a very precise resistance. If you do hit and miss charge cycles of the roomba or leave it charging too long, it either develops a flase memory of the above two conditions, or gets HOT and the electrolyte paste dries out. Fix is to wear it out, charge 14hrs, wer it out againand repeat 3-4x. Then recharge and use. If that doesn't fix it, the batteries are too dried and need to be replaced.
Apr 08, 2009 | iRobot 5800 Scooba Vacuum
Oreck Electrikbroom (battery) won't hold charge and pick up dirt.
Battery needs to be replaced. All rechargeable batteries have limited recharge cycles. NiCad's are usually used in these and also develop "memory' which keeps them from recharging fully.
Contact Oreck or reputable dealer for replacement.
Nov 15, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Bissell 52889 Flip-Ease All-in-One Vacuum and Mop Vacuum Logo
59 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
