Question about Syntax Olevia 537H Television
No Power We have no power, took off surge protector, unhooked everything, then re-hooked, checked outlets and still no light and will not turn on.
  • Syntax Master
  • 3,866 Answers
You have a bad power supply unit that would need to be replaced in this TV.
Posted on May 21, 2009
Turn tv off left for weekend came home no red light no power
check the power cable and socket, and also check the fuse of the TV by opening the back panel.
Mar 19, 2015 | Televison & Video
Had power surge. Tv was on surge protector. Now no power will come on and just makes a buzzing sound.
Have you tried plugging it in without the surge protector? I would wager that either a) the surge protector needs to be reset/turned on and off depending on the model or b) either your TV and/or surge protector have been damaged by the power surge.
Try plugging the TV straight into the outlet and see if that helps.
Oct 25, 2012 | Televison & Video
I had a power surge about a month ago and now my wii will not turn on. My wii is pluged into a surge protector.
I posted this elsewhere on here too, but I'll post it here too so it helps you.
This is a common problem with the Wii. You wouldn't believe how often I read about this. I'm very surpised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 09, 2009 | Nintendo Wii Console
Wii will not turn on even though it has power and everything is connected. Help?
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
My Wii stopped working. Nothing lights up.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapterthat needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 04, 2009 | Nintendo Wii Console
Wii work for 3 weeks will not turn on .
There is no light on the front, correct? No red, yellow or green?
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii. This is a common problem with the Wii. It happens almost every time there is a power surge or the power goes out, etc. Even if it's hooked up to a surge protector, this happens.
Power will come back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Nov 30, 2009 | Nintendo Wii Console
My wii will not turn on, I have never had a problem with it before. I checked all of the plugs and everything seems great except it will not turn on.
It seems every 5th problem I see is this issue. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii or in the Owner's Manual.
Power will come back on, or you'll go to turn the Wii on one day, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
Nov 29, 2009 | Nintendo Wii Console
Everything is plugged in, and it wont turn on
It seems even 5th or 6th problem is this. The AC adapter needs to be reset. Unplug it from the wall outlet for 5 to 10 minutes (NOT from the Wii, it HAS to be from the wall outlet).
Nov 22, 2009 | Nintendo Wii Console
We moved our TV from it's normal spot (hooked into different power source and cable outlet) and now it's dead. It won't turn on at all. We moved it back to it's old spot and still no luck. We bought it...
If it was plugged in during a power surge without a surge protector, there is a possibility it could be dead. Or if it was plugged into a new outlet without a surge protector, especially if it was never properly shut off before the move, that could kill it. Try unplugging everything and letting it sit for 30 seconds, then try again (with a surge protector if you have one)
Oct 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Out of Range
Do you have power to the base? I've seen this message on several cordless phones if the base is unplugged, the power brick has failed or the power adapter was plugged into a power strip (or surge protector) that has been turned off. It can also happen if the circuit breaker for that outlet has tripped.
First check that the power adapter is plugged into an outlet and the other end is plugged into the base. If the power brick is cold, check that the outlet has power by plugging in a different device (like a lamp) and turning that device on. If there is power, than you need to replace the power adapter or the entire phone (if you can't match the amperage output of the adapter). If there is no power at the outlet and the adapter is plugged directly into the wall outlet, check your circuit breaker for that outlet.
If you used a power strip or surge protector, check if it is on. For a surge protector, check if the surge protection circuit light is on. Replace bad surge protector.
I hope this helps.
(I have seen someone intentionally turn off a surge protector during an extended power outage and then fail to turn it back on after power returned. The individual forgot that they had turned things off before they called for assistance with their phone.)
Aug 17, 2017 | GE -25893GE3 Cordless Phone
Syntax Olevia 537H Television Logo
158 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Jaime Hernandez
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
