Question about Cyber Acoustics A-3780 Computer Speakers
Replacement wired remote control pod - Cyber Acoustics A-3780 Computer Speakers
Turn signal relay 2008 jeep location
There is no relay , controlled by integrated power module . Electronics !
Feb 12, 2016 | 2008 Jeep Grand Cherokee Laredo
How to program comcast xfinity remote to control pod
This not possible as there is no infra-red receiver on the speakers.
Apr 03, 2014 | Micro Innovations MM600D Computer Speakers
On my new Bose I pod dock the remote doesn't work properly. The volume and power buttons work but track switch does not.
1) replace new batteries with the same mark and polarities and full charges.
2 open the remote and clean it the keypad from dirty, oxide, and corrosion,with c.cleaners.
3) Proceed again,
God bless you
Oct 13, 2012 | Televison & Video
How do i connect an ipod in a car
hi,
you connect your i-pod to the car stereo using 3.5mm stereo connectors on each end. If your car does not support stereo input in the aux(or if it does not have a sound input jack), then you can also use the cassette adapter. Or if you have a 30 pin connector, your I-pod is recognized immediately. i have attached an image showing my car with i-pod.please rate my solution as helpful.
Apr 02, 2010 | Apple iPod MA446LL/A MP3 Player
Cyber acoustic A3780 remote control schematic I receive the speakers in gift but the remote control is missing
replacement wired remote control pod that will work for the a3780 2.1 sound system
14.99 which includes US mail with visa or master card
Cyber Acoustics, LLC.
3109 NE 109th Ave
Vancouver, WA 98682
USA
(360) 823-4100
Mar 18, 2009 | Audio Players & Recorders
Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Oct 03, 2008 | Bose Companion 3 Computer Speakers
One controller pod...being split for two speaker sets?
Technically it's not a KVM connector.
A KVM switch uses a DB15 serial connector.  Just like a monitor uses a DB15 for it's VGA connection.
The pinout for the control center's DB15 connectori is not likely to be the same as either one of those two types of devices.
Unfortunately, there is no way to make one pod work with two sets of speakers. The reason for this is that the voltage supplied to the control center comes from the sub-woofer.  You can imagine having two sources of power connected to one, single control center...
The control center would not know which sub-woofer and power system to regulate.  You would end up with issues revolving around power distribution, volume levels being variable - or worse.  More than likely, you would either overload the control center or it would simply not be able to keep up with the demand for both systems simultaneously.
I myself just had my set of Z-5500's RMA'd to Logitech under the exact same circumstances.  I just received my new set today.  Retail box and everything.
He was NOT kidding you.  I had to make him repeat himself just like you did.  LOL.
But I sent the control center, remote and purchase receipt with them.
5 days later, I found out DHL almost had my package here.  (Although I was lucky.  The turn-around time on the RMA is subject to supply and demand.  I was quoted 6-8 weeks at one point due to their lot being completely empty.  They are manufactured and shipped from China according to the rep I spoke with...)
My advice to you is to get right on the RMA process.  Get your incident number from the Logitech rep who sets up your RMA.  Get those two pieces sent in as soon as you can.  Do what I did.
To do this, call the following number.
General Technical Assistance/RMA: 646-454-3200
Package the remote, control center into a box snuggly.  WRITE YOUR INCIDENT NUMBER given to you by the Logitech rep on the receipt.  Include the receipt in the box.  Take it to the post office and send it by USPS Priority mail.  Get "Delivery Confirmation" on it.  All told it came to just under $10 for me.
Send it to the following address:
Logitech Incorporated
6505 Kaiser Drive
Fremont, CA 94555
ATTN: Incident Number# <put your incident number here>
You will also be instructed to send a copy of your receipt by way of fax.  WRITE YOUR INCIDENT NUMBER AND PERSONAL INFORMATION ON IT BEFORE FAXING.  (Or at least on a cover letter.)  They're supposed to send you an email to let you know that they received the fax...but I never received one.  Good thing I included a second copy with the control center and remote...because that's the one they used for processing.
FAX: 702-269-3439
I have pics of the shipping order that came on the box, too.  If you would like to see this proof, let me know.  I'll be more than happy to post plenty of pics that show my old set (sans the control center of course...) and the new set.
But don't delay like I did.  Mine was two days away from expiration of the warranty before I sent in the parts.  LOL.
Any more questions?  Let me know.  :)
Cyryl
Jul 20, 2007 | Logitech Z-5500 Computer Speakers
Cyber Acoustics A-3780 Computer Speakers Logo
57 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
