Question about Motorola Mobility Hk210 Universal Bluetooth Headset - Black/dark Gray - Retail
Motorola hk210 not prompting to put in code - Motorola Mobility Hk210 Universal Bluetooth Headset - Black/dark Gray - Retail
How to get Motorola Karma to ask for subsidy code
May be your code will be wrong..Get the subsidy password from http://www.superunlockcodes.com/ .It helps to unlock your motorola easily.
Mar 23, 2012 | Motorola Mobility Karma QA1 Cell Phone
Can't pair up my bluetooth to phone
Consult your bluetooths manual for how to put the device into pairing mode. Once it is in pairing mode search for it in your phones bluetooth menu. Select it, if prompted enter the pin code 0000.
Rylan
Dec 15, 2010 | Motorola Mobility H371 Bluetooth Headset
I forgot my security codhow do i unlock iunlock my motorola rival
When prompted for the lock code, enter *228 and then press send. When prompted choose option 1. This has worked for me in the past.
Sep 06, 2010 | Motorola Mobility Rival A455 Cell Phone
I have Motorola W218 locked by Optus network. I
Switch the phone on and wait 2+ hours you will see "enter subsidy code appear put your unlock code in there.
Mar 19, 2010 | Motorola Cell Phones
How to unlcok a motorola BZ60
Enter a non accepted sim card (oine that is not from the network the phone is locked to. You will be prompted to enter that code. If you are not prompted..simply leave the phone on for about 1/2 hrs to 3hrs and you will be granted the option to enter that code.
Aug 04, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Add new contacts to moto razr when there is unknown unlock code
when prompet for lock code press the menu buttons so that the phone says security code put 8 zeros hope this works, this will overide the lock code
May 13, 2009 | Motorola Mobility RAZR V3
Unlock code
try 1234 or 0000 if that does not work then whenn the phone prompts you for the unlock code , press the menu key now the phone will prompt you for the sec.code if you have not changed it, it should be 000000.
Oct 17, 2008 | Motorola Mobility RAZR V3
Motorola k1m
try 1234 or press the menu key when the phone prompts for the security code enter 000000.
May 30, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Unlocking procedure
I think you need to insert the original Sim card that was used when you set the code.  The code is stored in the card. Once you have done that and unlocked the phone, the phone will work with all other Sim cards.  Just remember if you set the code you have to use the card that was in use at the time.
You can take the phone to a shop and they might be able to clear it.  They have special software for that purpose, that isn't readily available to all.
Oct 31, 2007 | Motorola Mobility L6 Cellular Phone
HI
yup...77359752...try that...when you put your new sim card in it should prompt you for an unlock code...if it does no, leave your new sim card in over night...then try it...
Sep 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility Hk210 Universal Bluetooth Headset - Black/dark Gray - Retail Logo
26 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
