Question about Car Audio & Video
Sensor p0327 Nissan 350z 2004
SOURCE: convertible top sticks, will not fully open
The support bar right above your head has 2 elastic bands attached to it, one on the drivers side and one on the passenger side. After time they lose their elasticity and don't pull this bar (the one with the top attached to it) down when you retract. If it doesn't pull down, it will stay up (forward) as the frame retracts and get jammed up in the rest of the frame. Worst case it will pop the metal clip which holds the center of the cloth top to it (it is the length of the bar and spot welded to it) off. It will also put holes in your top on both sides as they don't fold down under and instead get crimped in the frame. Temp solution is to push that bar down as it retracts. Permanent solution is to repair the elastic sooner than later before it wrecks havoc with the whole frame and motor.
Posted on Oct 08, 2009
  • 1348 Answers
SOURCE: fan wont stop running after turning off 2004 nissan 350z
there is an after run module controlled by a fan switch that will run the fan if the engine compartment is hot.the switch could be shorted,or the module is bad.the fan normally runs for a few minutes then turns off.
Posted on Oct 23, 2009
SOURCE: My power seat won't work on my nissan 350z.
It it most likely a blown fuse
Posted on Nov 28, 2009
ginko
  • 19396 Answers
SOURCE: 2003 nissan 350z camshaft sensor location. engine
Hi.
The CPS is located near the back of the head. It is held by a single 10mm bolt and has a connector with a wiring attached . Below a diagram.Click on the picture to enlarge:
Regards.
Ginko.
Posted on Feb 18, 2011
emissionwiz
  • 76630 Answers
SOURCE: How do you replace a Nissan 350Z knock sensor?
Hello
The knock sensors (one for each cylinder head on the V6) are located on the inside of the cylinder heads, in order to replace them the upper intake manifold must be removed. It is always recommended on this engine family that not only replace the 2 knock sensors but that you also replace the short sub wiring harness to the knock sensors from the main engine harness as it is many times the a common cause of the knock sensor code(s) in the 1st place.
Posted on Oct 31, 2011
Engine diagnostic codes P0300 and P0327
G'day Gail, sounds bad, if you haven't got this fixed yet get back to me. Stay well Greg.
Jan 05, 2014 | 2004 Nissan 350Z
Which are the best tires for Nissan 350z 2004 ( which does not make sounds)
For a performance summer tire the Continental ExtremeContact DW is very highly rated for sound comfort.
For an all season performance tire look at the Continental ExtremeContact DWS.
best wishes
Jan 02, 2011 | 2004 Nissan 350Z
My window on my 2004 nissan 350z is having an intermittent prob going up and down
Unfortunately the sensor is going bad in the unit. You should be able to find a sensor on ebay or craigslist for fairy cheap. From what I have seen they are easily replaced.
Aug 31, 2010 | 2004 Nissan 350Z
How to install a window 2004 nissan 350z coupe?
Remove inner panel carefully. find 2 black circle stickers and raise glass to access 2 screws holding glass. Door vent does not need to be removed.
Jan 30, 2010 | 2004 Nissan 350Z
2004 350z convertible Top
The engine has to be running the parking brake set if stick shift or in park if auto. and your foot hasto be on brake.
Jul 22, 2009 | 2004 Nissan 350Z
Diagram for 04 nissan 350Z roadster
one under the hood and one at the drivers kick panel
Mar 29, 2009 | 2004 Nissan 350Z
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
