Question about Jet 2009 Dodge Nitro - 3.7L V6 - Performance Module
No heat in a 2009 dodge nitro v6 - Jet 2009 Dodge Nitro - 3.7L V6 - Performance Module
Firing order & Wire Routing for 2009 Dodge Nitro 3.7 w/ three coil setup
The firing order for v6 is 165432
The driver side cylinder bank is numbered from front to rear-- 2-4-6
The passenger side cylinder bank is numbered from front to rear 1-3-5
The picture is for your coil pack, hopefully. So you can see how the coil towers are numbered.
My database for 09 showed coil on plug ignition. Is this the original engine?
I did see info for 07--3.7L that did appear to show a coil pack in tune-up manual.
Apr 20, 2017 | Dodge Cars & Trucks
Is it a fuse that needs changing on an 08 nitro as fob and inside door locks not working
Your in good company! I googled this: 2009 Dodge Nitro key Fob not working unable to lock car
Large number of similar complaints. May be a recall or maybe should be. There may be a good solution somewhere it this search. Good luck.
Mar 12, 2015 | 2009 Dodge Nitro
Heater problems 2009 dodge nitro v6.
Possible, with rad cap off, let vehicle idle until coolant fan comes on then shut vehicle off for 30 minute cool down. Top up rad, install cap and drive and recheck heater operation and any overheating.
Jan 03, 2014 | Dodge Nitro Cars & Trucks
Heating not working 2009 dodge nitro
Ae you trying to get your Heater to work, or are you having problems wit it "over heating"?? Could be your heater core rusted out, or your thermostat not opening?? Depends... Good Luck!!
Dec 27, 2013 | Air Conditioning and Heat for Dodge Nitro
Dodge nitro engine code u110c, u1403,u0141,u110e
what do these code mean u110c,u0141,u1403,u110e for dodge nitro 07
Nov 12, 2011 | Cars & Trucks
I need a diagram for a serpentine belt for a 2007 Dodge Nitro
The diagram you requested appears below:
2007 Dodge Nitro 4.0L V6 Serpentine Routing
Oct 08, 2011 | 2007 Dodge Nitro R/T New Cars
Where is the oil filter on a 2007 dodge nitro v6
You can access the oil filter easily from underneath next to the front, driver-side wheel at the front of the engine. There is clear access to the filter there.
For more info on Dodge Nitro, visit the forum at
http://www.dodge-nitro.com/dodge-nitro/
Aug 08, 2009 | 2008 Dodge Nitro
Jet 2009 Dodge Nitro - 3.7L V6 - Performance Module Logo
67 people viewed this question
Top Jet Wine & Spirits Experts
deton8 von Splosion
Bill Boyd
Dave braun
Dave braun
Are you a Jet Wine and Spirit Expert? Answer questions, earn points and help others
