Question about Lenovo Tablets & eReaders
No sound tablet - Lenovo Tablets & eReaders
Sound not working on my tablet
hi Claire.
How do you fix the volume on your tablet? To verify the volume when audio or video are not playing:
  1. From the home screen, tap All Apps.
  2. Scroll to and tap Settings.
  3. Tap the DEVICE tab.
  4. Tap Sounds and notifications.
  5. Tap and drag the Media slider to the preferred volume.
Troubleshoot audio playback issues on your Samsung Galaxy Tab 4
https://support.sprint.com/.../WTroubleshootingGuide_542_GKB76043-dvc8270006prd Search for: How do you fix the volume on your tablet?
you could try this link as well.
no sound on tablet
or this one.
Sound not working on my tablet Google Search
Nov 27, 2017 | Tablets & eReaders
Sound in speakers is lousy
Tablets are notorious for bad sound. I use a volume adjuster app to boost sound and use earphones.
Apr 02, 2016 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
My headphone jack not work when i put it in my tablet i can still here the sound from my tablet and the headphones from the tablet it is a irulu Tablet,
Make sure you push the headphone plug into the jack completely. If you're sure that it is, then the jack on the tablet has failed. The sound gets switched from speaker to headphone in the jack itself.
Aug 08, 2015 | Tablets & eReaders
My tablet sound is low even when i have my volume settings at the max
This may sound silly, bit do you have your tablet in a sleeve or cover? If so, check that the cover is not covering the speaker outlet(s) on the back of the tablet. If it is, a hole or slot cut into the cover over where the speakers are located should fix the problem.
By the way, a quick test to see if this is the proble is to operate the tablet with the cover removed. If the sound is now OK, it's the cover causing the problem. This happens more often than you might think...
Also, some tablet do have really poor audio systems and both low volume and low quality sound. Hopefully your tablet is not one of them.
Jan 01, 2015 | Tablets & eReaders
Hdtv connection but no sound control for tv
Hi I Have Kimo Malaysia tablete but not Start and Not Reset By Power&Vol + Keys Not Work...Please Help Me For Install Os Android This My Tablete Thanks Hassan
Email
flightsazan@gmail.com
h_flightsazan@yahoo.com
Site:
www.airship.blogfa.com
Jan 05, 2014 | Samsung Galaxy Tab 101 Tablet...
How To Unmute Sound
tablet setting icon gear shape has sound display option from ringtones to touch sound.And volumes,increase bar section on volume to maximum to enable sound in case it was disable.
May 09, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Sound gone on my archos 80 cobalt tablet
I have the same problem. No sound at all on my Archos Cobalt 80 tablet. Hasn't been dropped, bumped; just suddenly stopped working. Tablet has been formatted, soft and hard reset, backed up and restored to factory default settings, updated the firmware and still no sound. Any help is appreciated thanks.
Mar 18, 2013 | Archos Tablets & eReaders
No sound
Si i think your sound driver is not installed you should cheak ur drivers
Oct 15, 2012 | Irulu 7" Google Android 4.0 Capacitive...
It stopped working, went black and has a sound like a loud fan working. Can't switch it off or do anything with it. Just making this running sound.help please. Fay
HI baring 16 listen You can get do a hard reset on the Samsung tablet. I must warn you that if you do a hard reset on the tablet you will lose all of your data. Next if your hearing a fan sound in the tablet. The tablet it self may be struggling to do simple operations on it. Where did you buy the tablet from. The steps to doing a hard reset on the tablet are as follow. 1 You need to hold both the power button and menu home key buttons at the same time. You will see the reboot screen come up. DO a wipe user information on it. It will begin wiping the tablet. You will have to reset set up the tablet after it is finish.If you still hear the fan sound take it back to the place of purchase for an exchange. Hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Mar 21, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
261 people viewed this question
Top Lenovo Tablets & eReaders Experts
vojvodabudva
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
