Question about Panasonic Televison & Video
No sound black screen
Please describe your problem..panasonic tv 27g2 no picture no sound when i turn it on it makes the sound like it turns on but it stay on black screen and no sound . the lamp light on a little bit
You can see the Vertical Outpu IC(must be damage and resistor from the flyback tranformer), but check the main power supply STR. Some times this STR not seems damage when you test out of main board, but with voltage it funtion not well.(Sorry my English).
Posted on May 31, 2009
Hello! My Panasonic QuintrixSR picture becomes fuzzy then thick squiggly black lines appear. The whole screen turns black yet sound still on. Can I fix this or is the TV toast? Please help, thanks.
Hi there!
Your tv is not toast yet it can be fixed. get another screen and see if their any changes .if other circuitry are fine your screen should work perfectly
May 18, 2017 | Panasonic Televison & Video
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
The screen goes black. On every channel. Sound is perfect. Is the TV dead
Ok---let me describe something and you tell me if your case: Set comes on and has audio--after 2-5 minutes if you look closely at the screen do you see a odd and faint band of noise top to bottom and to the right of the center of the screen?
It takes a couple minutes and will be faint and easy to miss.
Let me know what you see.
Apr 24, 2012 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic 32" GAOO just atarted doing this...Turn
The Panasonic Gaoo sets were top of the line in it's day, the problem you are describing is a vertical deflection issue caused by bad solder joints and a few parts. I recommend a tv technician to fix the set.
Jan 09, 2011 | Panasonic CT-34WX50 34" TV
My panasonic TV has sound but no picture
same problem here mine is not a plasma just normal tv was working all fine turned it off came back in an hour turned it on just black screen all channels work with all sound
Mar 11, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Tv will not turn on, just makes a clicking sound
Brother this is problem usually  when either the fly-back (picture tube transformer )or tube  voltage regulator  Transistor is damaged or the picture tube has a short
Best of luck
Aug 12, 2009 | Panasonic Televison & Video
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb, www.bluestar-online.com
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Screen is messed up, getting worse
What your describing sounds like two differant problems OR the power supply is causing these two problems .. One would of course be the tuner and the other would be the vertical circuit .. Your going to need to seek out a profesional if you havent a clue about solid state electronicsand A tv is not a place to experiment! Good Luck
Jul 27, 2006 | Panasonic CT-36SX31 36" TV
Televison & Video Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
