Question about Proform 590T Treadmill
Louder humming sound from treadmill when increase speed
2 Suggested Answers
  • 75 Answers
SOURCE: The drive motor makes a noise which is louder at higher speeds
Bearing in the motor are bad. Replace your motor.
Posted on Jul 18, 2009
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
Jan 12, 2016 | Cars & Trucks
Why is my nordictrack T6.3 making loud humming sound all of the sudden?
You don't oil belts as oil will eat away at the rubber. Start with running the machine and checking for lumps of wax build up at rollers (most common issue) if this is not it try oiling roller bearings. But call manufacturer first to see if your warranty is still good because as soon as you touch it it will void warranty.
Jul 18, 2014 | Nordic Track NordicTrack T6.3 Treadmill
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
Nov 12, 2010 | Epic 425 Mx Treadmill EPTL88105 !
I have a whirring or griding in my drivetrain. I can coast donw a hill and let the engine idle and I still get the noise. It doesn't sound any different going around corners and gets louder as the speed...
this sounds like(no pun intended) you have a wheel hub bearing assembly failing. they will start a whirring or humming noise and then a growling or grinding noise the worse they get. from your description it is a rotational noise and gets louder and maybe a higher pitch as the vehicle speed increases. have this checked out right away so no further damage is done. they are not cheap assemblies as most GM and Saturn vehicles have the ABS sensor built into them(if your Vue has ABS).
Nov 06, 2009 | 2004 Saturn VUE
2004 Chrysler Crossfire 25,000 mls auto, road hum noise
MOST of the hums after a while come from the diff as the back axle does the driving and almost all its life runs the same way except when going in reverse ,is the rear diff meshing and worn on both the crownwheel and the pinion and the humming gets slightly louder the faster you go and almost goes when almost stopped and this can also be the slight vibration you get so get the diff oil drained and refilled and check if there is any metal in the oil when drained if so thats your problem But it will last for years like that..Let me know how you get on RON
Oct 23, 2009 | 2004 Chrysler Crossfire
Rhythmic thumping noise with increased speed
The problem is the rear roller has a bad bearing and needs to be replaced
Mar 11, 2009 | Bowflex Treadmill Series 7
Proform 590T Treadmill Logo
32 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
