Question about Dryers
Dryer A Hotpoint DT20
I have changed the snapped belt but have knocked 3 wires out of the front I am looking for the wire diagrame so I can plug them back into the right places.
  • 94 Answers
Open us the control panel and see if there is a wiring diagram in there.
Posted on Oct 21, 2007
The wiring to my hotpoint tumble dryer
You would have had to disassemble the dryer to replace the belt, so the video was correct. The door switch assembly wiring at the front of the dryer mates with a matching connector which you would have separated for cabinet removal. Don't know why you messed with control panel wiring for belt replacement but you can go to www.repairclinic.com and enter tcym 750c to see a list of common replacement parts and maybe a video showing disassembly of a generic Hotpoint dryer. You might be able to get an answer to your wiring question.
Aug 10, 2016 | Hotpoint Dryers
Wiring diagram for Hotpoint 31331r door catch
only 3 wires on most dryers one is for light other to shut dryer off when opening if plugged in wrong. dryer will run with door open
light will stay on when door closed reverse them if that happens
some only have 2 wires don't matter on them
need whole model# for more info
Jan 08, 2015 | Hotpoint Dryers
I have a hotpoint dryer that has a fire wire plug connected to it. The house i have now has a three prong receptacle on the wall. Can i just buy a three prong receptacle and tape off the extra red wire.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 29, 2010 | Hotpoint Dryers
How do I replace the dryer belt?
sorry see the make, here is how u do the job
Instructions Things You'll Need:
  • Screwdriver with interchangeable bits
  • Putty knife
  • New dryer belt for GE Hotpoint electric dryer
  1. Step 1 Unplug the dryer and pull it out from the wall. Take out the upside-down screws in front that hold down the top. In older Hotpoint models, they will be under the rim of the top in front. In newer models, they will be on the inside of the dryer door opening, facing up. Slide your putty knife under the top rim to pry it up and get your fingers under it. Lift the top off the machine and set it aside.
  2. Step 2 Take out the screws that hold the front of the dryer in place, which will be on the upper inside of the box, on either side, facing toward the front. Pull the dryer front off. Keep the side with the wire connections next to the dryer (so you don't have to disconnect the wires) while opening the other side away from it like a door. The wiring side will vary.
  3. Step 3 Slip the belt off the dryer drum from the front. It won't come out completely; it will be held in one lower corner by the motor assembly.
  4. Step 4 Remove the access panel on the lower part of the back of the dryer by removing the screws. Access the motor unit. Note the configuration of the belt in the pulleys, then slip the belt off the pulleys by pushing the larger pulley forward.
  5. Step 5 Slip the new belt onto the drum from the front, with the ribbed side against the drum. Re-string it on the pulleys from the back, in the same configuration as the old one. Manually turn the drum several revolutions to make sure the belt is straight.
  6. Step 6 Put the rear access panel back on with the screws you took out. Close and re-secure the front and top (in that order) as they were before. Plug in the dryer.
Jul 07, 2010 | Hotpoint Dryers
I have a Hotpoint Dryer and the belt snapped, we purchased a replacement belt but are having a hard time figuring out how to install the new belt. The instructions call this belt a drive shaft. Please...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt,felt seal, and drum.
Remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
The route of the belt will go around the motor pulley first, then it will go around the idler arm bracket with pulley, then around the drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 15, 2009 | Hotpoint Dryers
What's the easiest way to open up a dlb6850 dryer to check the belt?
Unplug the dryer.
The easiest way to check the belt is remove the plate on the lower rear of the dryer. Look in to see if the belt is attached around the pulley wheel.
The only way to change the belt is to remove the screws in the front panel. Open the door. Look up in the door opening and remove these screws. Then you can raise the lid.
If the belt needs changing you must remove the 2 screws in the top right and left sides of the front panel.Just inside the front panel.Then disconnect the door switch wires and remove the front panel.
Slip the belt over the drum. Then open the lower rear panel to reach in to put the belt around the tension pulley.
Nov 12, 2009 | Hotpoint Dryers
Belt snapped on tumble drier - hotpoint 9320
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Good luck,
I hope this helps
Nov 11, 2009 | Hotpoint Dryers
Reconnect wiring on a Hotpoint VTD00 tumble dryer
most electric dryers have a wiring schematic on the back or inside on the back pannel of the unit it self . try too look for one there and it might help you out
Oct 30, 2009 | Hotpoint Dryers
I wanr to change the drum belt - hotpoint dlb1550pllwh
hi, do this Step 1 Unplug the dryer and pull it out from the wall. Take out the upside-down screws in front that hold down the top. In older Hotpoint models, they will be under the rim of the top in front. In newer models, they will be on the inside of the dryer door opening, facing up. Slide your putty knife under the top rim to pry it up and get your fingers under it. Lift the top off the machine and set it aside.
  • Step 2 Take out the screws that hold the front of the dryer in place, which will be on the upper inside of the box, on either side, facing toward the front. Pull the dryer front off. Keep the side with the wire connections next to the dryer (so you don't have to disconnect the wires) while opening the other side away from it like a door. The wiring side will vary.
  • Step 3 Slip the belt off the dryer drum from the front. It won't come out completely; it will be held in one lower corner by the motor assembly.
  • Step 4 Remove the access panel on the lower part of the back of the dryer by removing the screws. Access the motor unit. Note the configuration of the belt in the pulleys, then slip the belt off the pulleys by pushing the larger pulley forward.
  • Step 5 Slip the new belt onto the drum from the front, with the ribbed side against the drum. Re-string it on the pulleys from the back, in the same configuration as the old one. Manually turn the drum several revolutions to make sure the belt is straight.
  • Step 6 Put the rear access panel back on with the screws you took out. Close and re-secure the front and top (in that order) as they were before. Plug in the dryer.
  • thank you
    vijay
    (vote for me)
    Sep 23, 2009 | Hotpoint Dryers
    Putting the belt back on this dryer
    Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
    Jun 26, 2009 | Hotpoint Dryers
    Open Questions:
    Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
    Aug 20, 2018 | Kenmore Dryers
    Dryers Logo
    124 people viewed this question
    Top Dryers Experts
    Marvin
    Marvin
