Question about Dell Latitude D620 Notebook
Turn of problem
Let our Experts solve your "Some how my computer can not turn off by clicking from Start menu I have force shut down can you tel" Problem
  • Jubert Ledesma
    Jubert Ledesma May 11, 2010
    do you get any error message? when did this problem start?
  • Chris
    Chris May 11, 2010
    Sorry,
    but your prblem description is a bit vague, first what version of Windows are you running? Second what exact steps have you been trying to shut down the laptop?
    Chris
Shut down the system using the power button.....then remove the battrey and the ac adapter ....then without the battery and ac adapter...hold down the power button for 30 seconds....then put back only the battery....and turn on the system...after its turned on...then plug in your ac adapter.....then check....if not working out then contact dell
Posted on May 27, 2009
Unable to move cursor on lenovo x61
Are you trying to move the cursor with the trackpoint, a usb mouse, or the pen? Have you tried restarting your computer? Restarting would likely solve the problem. If you can't move the cursor to the start menu, you can open the start menu with the windows key, use the arrow keys to navigate to the power options. Use enter to select the power options and shut down or restart the computer. If this does not work, press and hold the power button for 5 or 10 seconds to force the computer to shut down.
What happened before this occurred? Did you install any programs or updates recently, or change any settings on your computer?
Apr 12, 2015 | Lenovo ThinkPad X61 Tablet PC
Tip
Method to reboot system using CD/DVD or without
There are Various(different) Methods to Reboot Your Computer 1.) Click "Start," then "Turn Off Computer," then "Restart." else 2.) Press "Ctrl," "Alt" and "Delete" simultaneously. Then click "Shut Down" and select "Restart." 3.) Press and hold the power key. Most systems will power down after about five seconds. This will force a hard power down. This method does not give hardware in the system, such as hard drives, a warning that power will be lost, so it is not graceful and should only be done if the above methods did not work. 4.) Unplug your computer and plug it in. And turn on the computer. This will also make force a hard power down, "Make sure that if the other command/option did not work (function)" so you should only do it if other methods did not work.
Reboot Using a CD or DVD 1.) Place "insert" the CD or DVD into the disc drive of your system (e.g E:,F: or G:) that you have. 2.) Restart your computer using any of the methods listed under "Various Methods to Reboot Your Computer." 3.) When prompted, press any key to boot the computer using the CD. 4.) Contact your computer's manufacturer if this does not work, and make sure that the CD or DVD is good. If not it will not work "Cannot run for booting" or computer may not be set up correctly, and various troubleshooting methods are required to figure out what is not working.
Else if you want to Reboot Your Computer into Safe Mode Here are the step to run in a "safe mode" 1.) Turn off your computer and Wait for few seconds. 2.) Restart your computer. 3.) Start tapping the "F8" key for a while and wait till the "windows advanced option" menu appear. 4.) When the "Windows Advanced Options Menu" appears, select "Safe Mode" using the arrow keys on your computer and press "Enter" key in your keyboard.
All the Best!
on Sep 13, 2010 | Computers & Internet
AVG COMES UP INSTEAD OF LOGIN
Might check your settings in AVG I know there are settings to scan every time the computer restarts so may need to turn it off or Let it happen then shut down your computer via the start menu and click shut down and then turn it back on and it may just be that simple
Oct 10, 2013 | Computers & Internet
Factory reset lenovo g580
Step 1:
There are a variety of reasons you may need to reboot a Lenovo laptop. These can include the installation of a new program, the dreaded blue screen of death or to free up memory that has been hijacked by a program that is now closed. There are three ways to reboot and all are simple to accomplish.
Click on your start menu button on your screen. Click on "Shut Down" or "Turn Off Computer." Click on the drop down box if you are running a version of Windows before XP (such as 2000 or 98). Select the "Restart" option and then click "OK." On XP or later versions, click on "Restart." The laptop will then reboot. Press and hold down the "Alt," "Ctrl" and "Shift" keys simultaneously. This will bring up the Task Manager. Pressing and holding the same keys again will force the computer to shut down. Press the power button to reboot the computer. This feature should be used when the mouse has stopped working and you cannot access the start button. Hold the power button in the "Off" position for approximately 5 seconds. This will force the machine to shut down. Press or slide the button again to reboot the laptop. Use this process when you get the "blue screen of death" or the computer is not responding to either the mouse or the keyboard.
Feb 22, 2013 | Lenovo Computers & Internet
Hp dx2200 computer won't power off
If your HP computer refuses to power down, this means that there are still programs open that Windows can't close. Normally when you select the "Shut Down" button from your "Start" menu, Windows closes all open programs, then closes itself, and your basic input/output system (BIOS) turns off all of your hardware. If Windows can't close all open programs, your computer won't be able to power off. This means that you must close these programs yourself.
Right-click on the window of an open program on your Windows taskbar (Bottom of Screen) Click "Close Window." Windows manually closes the program. If a window appears on-screen indicating that Windows cannot get the program to close, click the "Force Close" button in this window to have Windows force the program to shut down. Repeat "Step 1" for any additional programs that are open on your computer. Click "Start." Click "Shut Down." Hope this helps.
Dec 10, 2012 | Computers & Internet
I can not shut off the computer because something is still running in Finder, apparently. I get a message to close whatever is open in Finder and try again. I can't find what is open. My grandson...
Go to the apple menu then down to force quit if there is anything other than the finder running select it and then click on force quit, then try restart. If it still does not restart, do a forced shutdown by pressing down on your start button until it shuts down.
Hope this helps.
Sep 21, 2011 | Apple Computers & Internet
Rvhost.exe,windows can find this file...etc.that sentences always appear when i turn the laptop on.how can i solved the problem?
Follow these steps to restore your system files-
1. Shut down the computer.
2. Turn the computer on and immediately press F8 repeatedly until you get the "Advanced Boot Options" menu.
3. use the down arrow to select "Safe Mode" and press enter.
4. Window is should start with a "Help" window.
5. In the help window there is an underlined "What is System Restore?"
Click on that and "Click to open System Restore"
6. click on that and a new window comes up recommending restoring to a previous state.
7. Click ok and the operating system should restore your computer successfully and reboot into normal mode.
//javaftper
Aug 04, 2010 | Computers & Internet
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
How do i get out of hibernate mode and get into standby
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box.
    If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Dec 23, 2008 | LaCie Electron III 22" CRT Monitor
Printer will not stop printing
Let the printer run out of paper. Then left click START, left click SETTINGS, left click PRINTERS AND FAXES. Right click on your printers icon to view the drop-down menu. Left click on OPEN to view the print queue. If any jobs are displayed, clear them by left clicking on PRINTER tab in the queue display. From the printer drop down menu, left click CANCEL ALL JOBS. This should solve the problem. If not, shut down , turn off, and unplug your computer and all periferral devices from the wall. and unplug the printer from the computer, Wait at least 30 seconds and reconnect all devices. Turn all devices back on and check operation.
Jun 11, 2008 | Brother MFC-9420CN All-In-One Laser...
Dell Latitude D620 Notebook Logo
125 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
