Question about Garden
John deere won t start - Garden
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
harlan301
  • 205 Answers
SOURCE: john deer 310 g wont start after it sitts a day
if its turning over check your spark. if you have spark remove the air cleaner and spray some carburetor cleaner to see if it start than stops- let me know
Posted on Oct 14, 2009
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
GodBlessU
  • 3513 Answers
SOURCE: I have a John Deere
Hi
Unhook the fuel pump feed to carb line and place it over a gas can with ignition disabled to see if it is pumping any fuel at all. If you are getting fuel past the filter and pump (should be low pressure) your next bet would be to check the carb itself. Many smaller motors that aren't run often can develop deposits or contaminants that clog small ports or jets in the carb and prevent fuel from making its way into the motor. If you have any available you may want to try spraying a little starting fluid into the carbs while cranking to see if it will help it turn over.
However if you are getting gas out of the bowl, then it can't be a plugged fuel filter. It could be bad needle-valve or blocked passage. Take the carb apart and soak it overnight in Lacquer thinner then blow it out with an air compressor. The float should be set slightly higher than level with the carburetor upside down.
Also check this helpful link to troubleshoot your issue:-
http://www.lawnmowerman.tv/Troubleshooting.asp
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 19, 2011
SOURCE: My John Deere x300 won't
I am not familiar with this particular model but from the smell of raw gas I check the air filter and choke first to see that you are not flooding it. You could also take out the spark plug to see whether it is wet with gas.
Posted on Aug 07, 2011
L 115 19 HP 42" JOHN DEERE RIDING TRACTOR WON"t start
There are several safety switches such as under the seat, blade engagement, neutral switch....all must be in working order and the lever in the proper position to get fire to the starter.
Oct 18, 2014 | John Deere Garden
John deer gx75. 9hp kawasaki. Turns over but won't
check and clean air cleaner. Check main jet for blockage.
Jun 23, 2013 | Garden
John Deere 345 won't shut off
I would start with either replacing the key switch, or tracing the wires to make sure they are not touching together somewhere, completing the ignition circuit.
Apr 14, 2013 | Garden
Got new brakes and now the hubs won't turn
You need to adjust the slack adjusters
Jan 31, 2013 | John Deere Garden
John deere X575 cuts off then won't resatrt
check for spark when it doesn't start the coil could be bad
Sep 02, 2012 | John Deere Garden
John Deere 310G that the hydraulics quit working
You just go to the link I attached I'm sure you will get the solution of your problem.
John Deere 310G
May 29, 2017 | John Deere Garden
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
Garden Logo
249 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
