Question about Goodman Heating & Cooling
LITTLE AIR COMING THROUGH THE VENTS
THE UNIT WILL COME ON AND THE FAN WILL SPIN BUT IT DOESNT PUSH MUCH COOL AIR THROUGH THE DUCTS
    President:
  • 3,433 Answers
Make sure a/c is not in exhaust setting or vent.
Posted on May 21, 2009
Air conditioniong not coming out of all my vents
Hi Linda:
If there is cold air coming out of some of the vents then the air conditioner is working.
The problem will be with any of:
- the ducts that connect the vents to the air conditioner,
- the "gates" that allow air into the ducts, or
- The switching or power that controls the gates.
I suggest you try different settings, record which vents are not working under what circumstances, and in that way determine where the problem is. Once you've isolated the problem, it is usually a lot easier to fix it.
Cheerfuls!
May 17, 2015 | 2009 Toyota Corolla
Ac unit doesn't cool one bedroom well, new unit what am i doin wrong.
Check the air vents in that room to ensure they are open. Or try closing a few other vents a little to try and push the air to that room.
Jun 06, 2011 | Heating & Cooling
Fan runs but no cool air or any air coming thru ducts
Be sure the "fan running" noise you hear is actually the fan and not just the refrigeration pump. The unit would still make a running noise but the fan may not be turning.
Check to be sure the filter is clean and that all vents are open.
Jul 19, 2010 | Dometic Rooftop RV Air Conditioner
Fan unit does not come on.
Hello
if im reading this correctly,you need to push start your fan motor?
Either the motor start capacitor is bad or the motor windings are bad.
If the motor is not coming up to full speed or is faulty you will not get good cooling.
Sounds as you may need a new motor.
Jun 01, 2010 | Ruud Central System Air Conditioner
Fan blowing air not coming in the house blowing threw vents
check to see if those ducts have dampers if the do make shure there open and if they are open maybe close some of the others to balance or improve the preasure in the ducts that arent blowing enuf
Apr 04, 2010 | Ruud UBHC Air Conditioner
Cool air comes out of the back unit vents and hot in the front
under the dash on the bottom of the heater box there is a little selector motor most likely that motor has gone bad
Aug 07, 2009 | 2000 Ford Expedition
I have a dometic duo-therm. No air coming through ducts.
Sounds like the ducting have come apart in some areas or blocked in some way. Take the supply grills off and with a shop vacuum try and reach as far as you can.
Mar 18, 2009 | Dometic Rooftop RV Air Conditioner
Central Air Conditioning
It sounds like a restriction in your ducting. Feel the A/C vents in the hot rooms to see if cold air is blowing out of them. If the ducts are restricted, then it is possible that the air conditioning coils are freezing up from lack of circulation. Inspect the ducts if you can to see if there is any restriction.
Note that even if you feel air coming out of the ducts, it could be ambient as opposed to cold. The best thing is to measure the air temperature coming out of the ducts. It should be around 20 degrees colder than the ambient air at the intake of the A/C.
Sep 03, 2008 | Computers & Internet
Blower Turns off if ac unit comes on. No air coming through vents
This only could 1--2 things, a bad circuit board fan relay or bad thermostat. To check for bad thermostat, take off the front cover to reveal the 4-wire terminial and jump the red-wire (power)-cool,(yellow -y or blue)--- green--fan white-(heat)..........red to yellow-or y=cool. Thank-you-very-much!
Aug 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
73 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
