Question about Bosch Exxcel WFO 2465 Front Load Washer
Bosch washer not going through it's cycles, timer counting down but no action
SOURCE: exxcel 1400 express washer, spin
key symbol flashing
machine wont go
Posted on Apr 20, 2008
  • 3 Answers
SOURCE: 2007 Bosch Washer WFMC 3301
It may be possible that you are using too much soap. There is a turbidity sensor that checks for soap in the water. It will keep rinsing until it thinks the soap is gone. You did not state if you are ever able to complete an entire cycle or not. If the cycle never completes, it is possibly a problem with the main circuit board. Have you allowed the machine to complete a cycle?
Posted on Jul 17, 2008
  • 11 Answers
SOURCE: wfmc2100uc Bosch Washer
It could be the brushes on the motor or the belt has come off
Posted on May 09, 2009
SOURCE: I have a Bosch washer, model number WFK 2401 that
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Posted on Aug 06, 2009
  • 1382 Answers
SOURCE: bosch washer dryer WVT2850GB error code E06
Remove the rectangular fascia at the bottom front of the machine - on my model you only need a coin to turn the two plastic screws. Unclip the black rubber drain pipe, remove the plug from the end and drain the water into a bowl (or several bowls).
Then undo the round plug at the bottom left of the machine (more water will come out) which will give you access to the extractor pump. Check that there are no obstructions in there and that the small propeller in there can turn freely.
If there is no obstruction there then we move onto the next steps.
If you can figure out how to remove the front of the machine then you will find this part easier
First, TURN OFF THE POWER. Then, on the front of the machine, on the bottom left, undo the screws that fasten the extractor pump onto the front of the machine. Then pull the machine out from the wall so that you can get to the back of it. Remove the back of the machine by taking out the ten or so screws.
Looking in from the back: At the bottom-front-right of the machine you will see the extractor pump. It will have two hoses attached to it - a fat one and a slightly thinner one. Reach into the bottom of the machine and remove the power plug from the back of the extractor pump. Then, using a pair of pliers (or something similar) to open the spring clip, remove the thinner of the two hoses (the drain hose) from the pump unit. This can be fiddly - especially if you're doing it from the back of the machine.
Pull the hose out of the machine and check it for obstructions. If there are no obstructions in there then move onto the next step.
Reach back into the machine and, again using the pliers, remove the fatter tube from the pump. Remove the pump from the machine and check it for obstructions in the entry and exit holes, and also make sure that the propeller isn't obstructed. Then shake and squeeze the fatter tube to see if there is an obstruction in there
Best of luck.
Posted on Mar 30, 2010
Bosch washing machine starts filling with water, then does nothing, timer counts down but no movment
have a technician check it out as it may be a board problem
normally the fill level switch ,when the set water level is reached activates 2 things
it stops the water in and at the same time moves the program on to start the wash cycle
so it is either that switch or the program board
Aug 13, 2015 | Bosch Washing Machines
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
WE have a Maytag Neptune TL and it is stuck in the wash mode... as though the timer does not register to move on to rinse.
Katie,
I'm and owner that knows the machine very well. If you are someone has some basic skills you can repair the machine.
It will come down to how much down time you can tolerate.
What I think is the issue is that the Upper One-Way bearing is seized and when the machine enters into spin cycle of the selected wash cycle the washer can't spin the wash basket. The Control Board tries to enter the spin cycle over and over again. There is no software routine in the Control Board to sense this and the machine keeps trying execute the spin cycle of that wash cycle......Timer never counts down.....
Place that wash load in a Spin Only cycle. If my diagnosis is correct then the machine will do the same thing never count down on the LED display in the Spin Only cycle.
All these machine are ready for a Tub Seal replacement and I can direct most owners thru the process. The cost is in the area of $60 for Tub Seal, ****** O-Ring and Outer Tub bearings. If you need to replace the Clutch Pulley around $80 additional. If you are the original owner I'm sure you have been thru that.
Here is a link to replacing the Tub Seal and Outer Tub bearings. See if this is a direction you want to go. FAV6800A/FAV9800A Outer Tub bearing replacement
Here is a link to what I believe is your issue.........it just took me a long time to extract info from the owner on the failure. [FIXED] Maytag Neptune, Timer Problem
Maybe a FIXYA tech can jump in and add what they think might be the issue and a troubleshooting/repair path to follow.
You can make the machine last for a long time............way beyond the 3.5 yr. to 6 yr. point of most failures.........but each owner has to decide their course of action.
I go by dh1200s on most washer DIY forums including this forum.
Sep 06, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I start the wash cycle timer reads 1:02 machine runs and timer counts down to 54 mins. then resets to 1:12 mins. which inturn adds approx. 18-20 mins to wash cycle why the reset??
I had a similar problem with ours and had a repair guy come out and look at it. He suggested running a couple of heavy bleach cycles through the machine. He said that sometimes if you use too much detergent (especially if you're not using the "High Efficiency" type of detergent) detergent builds up on a sensor in the machine and causes longer than necessary wash cycles. We actually ran 2 cycles of bleach and then a couple more with no bleach or detergent and the problem cleared up.
May 02, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Make sure there is no water in drum.
Remove and clean pump filter, this is usually located at the bottom front right of washer, behind drop down cover.
Unscrew anti- clockwise to remove and clean.
Good luck.
Dec 13, 2009 | Bosch Washing Machines
Bosch Classixx 6 - tried washing a load on easy care which on normal cycle takes 48 min, the timer counts down for about 5 mins but doesn't sound like any water is being drawn in. After the 5 mins or so...
i have checked all my tech info and error codes only go to f 12!! never had f 17 but based on description sounds like either flow sensor or inlet valve failure will need service tech to sort out but if either of these will not be expensive.
Nov 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washer keeps spinning water and not moving on to the next cycle
Sounds like the timer has gone bad and is not letting anything work. Washers, dryers and dishwashers have a timer that you set at the start and then the system counts down off of that. If that stops working it will run forever
Feb 12, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Wfmc2100uc Bosch Washer
Oct 20, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
May 18, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Exxcel WFO 2465 Front Load Washer Logo
35 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
